Old 05-15-2007, 07:15 PM   #26
onetonk5
Cereal Killer
onetonk5's Avatar
Re: 4WD to 2WD frame swaps
Gotcha......thanks
If I dont do it....somebody else will.
onetonk5 is offline   Reply With Quote
Old 05-15-2007, 07:35 PM   #27
milehightoyz
AttentionDeficitDisorder
milehightoyz's Avatar
Im going to try and cut down an extra longwheelbase 2wd truck frame i got laying around to a blazer wheelbase and see what happens as far as body mounts etc, this might be an easier route to take. we'll see.... great info thanks gringo
milehightoyz is offline   Reply With Quote
Old 05-16-2007, 06:00 PM   #28
onetonk5
Cereal Killer
onetonk5's Avatar
Got a little done to the front end today.
Old 05-16-2007, 06:03 PM   #29
onetonk5
Cereal Killer
onetonk5's Avatar
Question for people who have done a 2wd crossmember swap.....what bolt hole lined up? I have measured and measured against stock 2wd trucks and am still not sure that I have the crossmember in the correct place.Its tough to tell with the frame bing an inch hight than a 2wd...will know better when I get the steering stuff in place but it looks pretty close now...maybe a little too far back if anything.
Old 05-16-2007, 09:40 PM   #30
mike nutt
69fatmotor
mike nutt's Avatar
mark , the blazer is lookin good . give me a call when you get chance . i need to get by and check your work , i want to make sure you know what your doin and all
mike nutt is offline   Reply With Quote
Old 05-16-2007, 10:36 PM   #31
onetonk5
Cereal Killer
onetonk5's Avatar
Wife is going out of town tomorrow so I will most likely try to get the rear stuff started tomorrow...give me a call. Im gonna pm you my other numbers
Old 05-16-2007, 11:05 PM   #32
onetonk5
Cereal Killer
onetonk5's Avatar
I have a bolt in this original hole....anyone done this swap know if that positions the crossmember in the correct spot??
Old 05-16-2007, 11:26 PM   #33
oilyrag80
oilyrag80's Avatar
Dont rely on any holes lining up for correct position, if I remember right the crossmember hole ended up just forward of the frame hole. just make sure the shock clears the upper a-arm and the centerlink clears the front of the crossmember before you drill any holes
oilyrag80 is offline   Reply With Quote
Old 05-16-2007, 11:33 PM   #34
onetonk5
Cereal Killer
onetonk5's Avatar
good suggestions....dont have any shocks or steering on it yet
Any way you could measure against something...like the factory rear leaf spring bushing hole.....or anything for that matter...this thread needs concrete measurements
