Old 05-15-2007, 12:02 AM   #1
67TexasC-10
Rear Suspension
My 67 has the original trailing arms and coil spring and panhard bar set up however over the years some one added leaf springs, i just wanted double chck that these are unoriginal as i plan on removing them tommorow. I would guess they were used as helpers for heavy loads as it was a work truck. Can anyone think of any possible reprocussions from their removal?
Blake
67TexasC-10 is offline   Reply With Quote
Old 05-15-2007, 12:17 AM   #2
67 cst swb
67 cst swb's Avatar
Re: Rear Suspension
Are they mounted to the rear of the truck, and go to a pad mounted on the trailing arms/rearend? If so, these are factory "helper" type spring.
other will add in info....
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 05-16-2007, 12:07 AM   #3
67TexasC-10
Re: Rear Suspension
As you stated the springs attach to the frame and I would guess are helper factory options. If I were to remove them would it cause any sort of bad thing? I am on a saga to lowering it and they need to go...
Old 05-16-2007, 12:09 AM   #4
st1x10
st1x10's Avatar
Re: Rear Suspension
They are just helper springs.
1970 Chevy C10 "Under Construction"
2002 Chevy S10 V6
st1x10 is offline   Reply With Quote
Old 05-16-2007, 12:35 AM   #5
67TexasC-10
Re: Rear Suspension
Then they are gone.
Old 05-16-2007, 12:46 AM   #6
67 cst swb
67 cst swb's Avatar
Re: Rear Suspension
Remove them... your good to go, they just help when you overload...
I trash all mine... lower is the way to go...
My Trucks:
Old 05-16-2007, 12:59 AM   #7
GREASEMONKEY72
GREASEMONKEY72's Avatar
Re: Rear Suspension
yea theyre just helper springs, mine are still on cause i havnt bothered to take them off but if youre taking them off instead of trashing them why not sell them on the classifieds board
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 05-17-2007, 12:42 AM   #8
67TexasC-10
Re: Rear Suspension
Thanks thats a great idea.
