Old 05-12-2007, 06:51 AM   #1
MD8349
1999 Chevy
MD8349's Avatar
99 parking break
I think this is a common problem w/ thease trucks I have not gone through all the threds on this site but what I need is the instructions on how to adjust the parking break and if anyone has pics. the problem is that it will not hold durring the state inspection. its silly due to i never use the thing. Thanks to whom ever can help.
MD8349 is offline   Reply With Quote
Old 05-17-2007, 12:16 PM   #2
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Re: 99 parking break
I'm a little late, but here it is if you still need it.
The parking brake must be adjusted any time the parking brake cables are serviced, or the holding ability is not adequate. Before adjusting the parking brake, check the condition of the service brakes. The service brakes must be adjusted properly before adjusting the parking brake. Refer to Drum Brake Adjustment in Drum Brakes.
Raise the vehicle and support the vehicle with safety stands. Refer to Lifting and Jacking the Vehicle in General Information.
Loosen the adjusting nut at the equalizer.
Set the parking brake by pushing the pedal down 18 degrees.
- Insert a 3 mm (0.125 in) pin into locating hole (1) in the pedal assembly.
- Push the pedal downward until the pin contacts the parking brake outer flange.
Turn the adjusting nut at the equalizer until the wheels rotate forward with a moderate drag.
Release the parking brake and rotate the rear wheels. There should be no drag.
Lower the vehicle.
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
