#26 |
Re: And the tear down begins
Front sheet metal removed.
#27 |
And, the removal of the cab from the frame. It's officially a frame-off resto now.
#28 |
Now, cleaning up the frame. You'd be subrised what some Bleche-White and a pressure washer can do.
#29 |
I think you've got too much time on your hands... The way it looks, I would've driven it as is for at least 5-8 years before thrashing it. Just my .02...
If you can't drive it park it! If you can't park it milk it! |
#30 | |
#31 |
Looks like you're making good progress!
I'll be starting the tear down of my truck next spring as well. Mine is in a fairly similar condition as yours was. Looks good from 20 ft, but you get up close and you can see the cancer. I had mine repainted 7 years ago, and its showing its age. I'm also going to convert it to a short bed with trailing arm suspension and air bags. Good luck, and keep us posted. |
#32 |
Re: Inside: My 68 shortstep rebuild progress.
OK It's been a while since I've updated. My dad and I have got alot done. The chassis is now complete short of installing the engine/tranny which we will do after we get the cab back and mounted from the body shop at which time we will also install the wiring harness, brake booster, and the remaining brake lines.
I hired a new body man in November. I haven't been able to talk to him or check on progress for the past two weeks due to being slammed for Christmas. The last time we did talk, he had most of the holes filled in the firewall. He wasn't making as good of progress as he wanted because of some of his bodymen being out sick. He actually has my truck at his house to work on it himself instead of it going through too many hands at his shop. He's maiking it his own personal project. Here are some pics of the frame after cleaned and painted sitting in the sun to dry. We used Rustoleum Semi-Gloss black rattle-can paint. This stuff works really well. It lays and blends reall good and matches from can to can. I've seen some paints that actully mismatch if the cans are from different batches. The new ECE drop spindle and 4"rear drop springs are also installed.
#33 |
Here is my engine painted after the new CompCams XE262H cam and new CompCams Magnum 1.52 ratio roller tipped self-aligning rockers and new Edelbrock True roller timing chain. The TH350 after a new coat of paint. The last picture is of my sway bar painted body color also.
#34 |
The completed chassis with the new Kustom Tanks fuel tank, fuel lines, brake lines from www.performanceonline.com, and ECE shock mount relocater kit and new KYB shocks.
#35 |
Here's some pics of new parts I've been recieving over the past few months.
Stainless bolt kit from MMS Accessories in GA Brake booster, brake lines from www.performanceonline.com
#36 |
New fuel tank from Kustom Tanks
New Hedman Elite headers(part#69648), Intake, VC, and O-rings from Summit
#37 |
Saying bye-bye to the cab, doors, bed, and small cab pieces going to body shop.
#38 |
Hot Rods For Life
Any updates? Looking good.
#39 |
![]() Join Date: Feb 2001
Man I wanna do another!!!!!!
