Old 05-18-2007, 07:52 PM   #1
bigblock79
67 Chevy Stepside
bigblock79's Avatar
? 87 350 fi engine
can i take a 87 chevy truck 350 with FI. and pull that intake off and put a 4 bbl. intake on it. will it work
1967 Chevy stepside
1976 BIG DOOLEY 454 turbo 400 4:11
bigblock79 is offline   Reply With Quote
Old 05-18-2007, 08:14 PM   #2
Eyegore
What Hump?
Eyegore's Avatar
Re: ? 87 350 fi engin
Pretty sure it will, I believe you have electric fuel pumps in the tank, not sure if that will interfere somehow.
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 05-18-2007, 08:56 PM   #3
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
yes you can iv done it. edelbrock make the intake it 209.oo with out the egr setup. here a picture of it on the block.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 05-18-2007, 09:31 PM   #4
lurch115
lurch115's Avatar
yes you can, but you need a vacuum advance distributor, and you'll have issues with the electric fuel pump (or pumps) that are in the tank because they run higher pressure that a mechanical pump....i just got rid of a truck that the p.o. had done that too....
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you."
'84 chevy half ton short box 2wd, 67,000 actual miles
'03 chevy 1500 HD crew cab 4x4 standard box, 6.0L
lurch115 is offline   Reply With Quote
Old 05-19-2007, 06:52 AM   #5
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Lightbulb Re: ? 87 350 fi engin
Hey guys i dont think he talking about doing it to an '87 truck i think he wants to put a '87 engine into an older truck but convert it from FI to a CARB.
If so you can do it but ya may want to change to cam and run something that will match up closer to the carb and intake combo cuz the FI cam is not gonna produce alot of vacuum.
And you can run a electronic distributor as well or any other type you want.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 05-19-2007, 09:19 AM   #6
Srubydo1986
The Crazy Machanic
Yes like i did i have a 1989 gmc jimmy motor that was tbi in to my 1986 which was cabarated.
I didnt change the cam and the truck runs great. i change the distributor ofcourse but thats all.
Like i stated before the main thing is the special intake. because of the catty cornered bolt aroung the carb area you need that intake. I got mine from edelbrock and the cost is 209.00.
hope this all helped Also i put v belt on theengine wish i had a serpintine setup.
newest additions
Old 05-19-2007, 09:27 AM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: ? 87 350 fi engine
Not trying to be an @ss, but why would you want to?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-19-2007, 10:05 AM   #8
Jonboy
Slots go on anything!
If you are going to put an aluminum intake on, an earlier intake can be used by slotting the 4 center holes. It would work for an iron intake too, but would take forever to slot the holes.
Jonboy is offline   Reply With Quote
Old 05-19-2007, 02:02 PM   #9
gotit
gotit's Avatar
thats right, been there! four middle holes have to be drilled,
gotit is offline   Reply With Quote
Old 05-19-2007, 03:16 PM   #10
bigblock79
67 Chevy Stepside
bigblock79's Avatar
i bought a 87 short bed and i am going to use the bed on my 79 bb truck and thought about the 350 in my 79 dd to replace the weak 305 so i need to change cam and intake thanks
1967 Chevy stepside
Old 05-19-2007, 03:45 PM   #11
gotit
gotit's Avatar
why would you have to change the cam?
[SIZE="6
Code:
HTML Code:
[PHP][/PHP]
"][/SIZE]
Old 05-19-2007, 11:59 PM   #12
bigblock79
67 Chevy Stepside
bigblock79's Avatar
change the cam for a little better sound
1967 Chevy stepside
Old 05-20-2007, 11:06 AM   #13
Srubydo1986
The Crazy Machanic
I will agree with gas prices going up after my conversion i wish i still had the stock tbi setup. but i dont and dont really know whats all involved in make a non tbi truck a tbi.
newest additions
Old 05-21-2007, 02:41 AM   #14
kevinr1970
Fuel pump?
The TBI engine won't have a provision for the mechanical pump.
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 05-21-2007, 07:38 AM   #15
Big Bobby O
Do you still have the parts truck? The whole parts truck? Why not use the wiring harness and the computer and run the TBI? You might be able to use the tank with the internal fuel pump.
I have an 88 with a rotted frame and I'm considering doing the same converson.
Big Bobby O is offline   Reply With Quote
Old 05-21-2007, 03:46 PM   #16
bigblock79
67 Chevy Stepside
bigblock79's Avatar
i got a 79 that i want to put it in and though of doing it that why how hard would that be
1967 Chevy stepside
Old 05-21-2007, 03:57 PM   #17
87 STEPPER
87 STEPPER's Avatar
Lightbulb Re: ? 87 350 fi engine
Actually that would be the best and easiest way to do it!
If you still have the complete donor truck then it's just a matter of removing the complete wiring harnass and engine and fuel lines and tank and installing it all in your '79.
It's alot of work but not that hard.
Plus you have a low maintenance & high reliability of a modern FI system in your truck.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
Old 05-21-2007, 04:33 PM   #18
kevinr1970
Its not even the complete harness as the ECM(PCM?) is on a stand alone harness I THINK.
Where's Russell when you need him...
2000 Tahoe Limited
Old 05-21-2007, 06:00 PM   #19
bigblock79
67 Chevy Stepside
bigblock79's Avatar
thanks the 87 does have 2 tanks and the 79 only has one could i do it and keep the one tank
1967 Chevy stepside
Old 05-21-2007, 06:59 PM   #20
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
They are "slightly" integrated for ground and power I think, but it wouldn't be too hard to pull it.
You can run the single tank directly to the TBI and bypass the fuel selector to use just one tank.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 05-26-2007, 02:38 PM   #21
gotit
gotit's Avatar
i took the engine harness off a 90 burban and plugged it in to my 86. i did have to splice into some of the wires. i have dual tanks, and since i did not have the factory dual tank selector harness. i had to run wires from my fuel pumps and use a toggle switch to turn left or right pump on, to switch the tanks i used my factory switch. if you can get it done tbi is a great running set up.
[SIZE="6
Code:
HTML Code:
[PHP][/PHP]
"][/SIZE]
Old 05-26-2007, 10:47 PM   #22
bigblock79
67 Chevy Stepside
bigblock79's Avatar
thanks i might have to try it
1967 Chevy stepside
Old 05-26-2007, 11:39 PM   #23
68K20 x Drill
Originally Posted by kevinr1970 View Post
Fuel pump?
No provision = blanking plate in place of.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs.
84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80
68 GMC C20 Parts? Truck
And a few cars
68K20 x Drill is offline   Reply With Quote
Old 05-27-2007, 09:43 AM   #24
bigblock79
67 Chevy Stepside
bigblock79's Avatar
it got a block off plate on it
1967 Chevy stepside
Old 05-27-2007, 10:34 PM   #25
kevinr1970
He asked if it could be done, I was just pointing out that the engine will have no way to run the mechanical pump; you will need to come up with an alternative (electric) fuel pump.
2000 Tahoe Limited
