Old 05-14-2007, 11:08 AM   #1
Hart_Rod
Hart_Rod's Avatar
Question Carrier bearing 101.....need some information
Need some help deciding on what carrier bearing setup to put in the 67 Crewcab. Originally it had to 2 carrier bearings and 3 drive lines. I plan on using only 1 carrier bearing and 2 drive shafts since I am changing it from a LWB bed to a SWB bed. I've noticed several different types. I'm guessing the difference is between 1/2 T and 3/4 T but I'm not really sure. Any information/suggestions/pictures would be helpful.
Also, I bought a SWB truck for the frame and it had 2 drive shafts and a carrier bearing. Thought that was weird for a SWB. I think it was orignally a 4 speed truck. Is that normal?
Hart_Rod is offline   Reply With Quote
Old 05-14-2007, 11:16 AM   #2
dan42
dan42's Avatar
Re: Carrier bearing 101.....need some information
Don't know about the 3 drive shafts on a SWB. I remember seeing a thread on a new carrier bearing that someone was using - it was polyethylene or something, and they were saying it was working good for them. You might do a search. Good luck with that project, it sounds like there's a lot of new ground you are going to cover that no one else has!
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 05-14-2007, 12:48 PM   #3
1lowdiesel
1lowdiesel's Avatar
my ccsb duramax has only 1 about a foot from the end of the cab. works well...when it's aligned right.
69 4wd V6 20k orig miles!!
05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored.
01 rcsb chevy 2wd 6bt cummins :devil:> build
xtremediesel.com
1lowdiesel is offline   Reply With Quote
Old 05-14-2007, 09:30 PM   #4
Hart_Rod
Hart_Rod's Avatar
Here's some picture of the "original" setup (2 carrier bearings). I also attached a picture to show the difference between a SWB chassis and a LWB chassis that has the cab extended 33", .
Old 05-14-2007, 10:02 PM   #5
GREASEMONKEY72
GREASEMONKEY72's Avatar
its a wee bit longer aint it, cant wait to see this thing when its done, but as far as the SWB having a 2piece, ive seen one with it also
personally i think id go with the 3/4T setup
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 05-14-2007, 10:31 PM   #6
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
My '88 extended cab longbox has the OE shorty th400 (bolt on yoke style) and one carrier bearing. Should work good for you too. Are you staying with the FF rear, or going 12 bolt? If going 12 bolt, I'd recommend buying a pinion yoke to "up size" from the puny 1310 joint to the FF's 1350 joint. especially if you are going to do any trailer pulling. 1310's don't live long in a heavy truck, especially if it is gonna have a heavy foot & power
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD
'72 K20 500 Cad/TH400/NP205 SOLD
'92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver
'72 Monte Carlo... sweet low mile toy
'11 Dodge Challenger IE 392 6spd... midlife car
jeffspower is offline   Reply With Quote
Old 05-15-2007, 07:50 AM   #7
Hart_Rod
Hart_Rod's Avatar
Do you have any pictures?
Old 05-15-2007, 05:00 PM   #8
bagged91
Out draggin'
bagged91's Avatar
My 91' Ex Cab LB had a 2 piece driveshaft with a carrier bearing & a slipshaft at the carrier bearing. My rear suspension had over 13" of lift and truck performed flawlessly at any rideheight. Wheelbase is probably going to be fairly close too... Somewhere I should have a pic of the chassis after doing the stockfloor bodydrop on it. I'lle look around tonight.
91 GMC Xcab LB-Bags/bd/caddy clip SOLD
72 C10 Cheyenne Super LWB SOLD
92 GMC K1500 Burb
72 C10 Burb (ex. Cheesewagon)SOLD
72 C20 Burb parts truck
71 C10 Burb "project"
bagged91 is offline   Reply With Quote
Old 05-19-2007, 09:45 PM   #9
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
Better late than never? I lost my digi cord, had to go buy a card reader. I'm sure I'll find my cord laying out in open sight now.
I swapped the OE Dana 70HD w/4.10's for a 14 bolt with new 3.21's. The 14's pinion yoke-to-axle centerline distance is shorter than the 70HD. I had to lengthen my rear shaft.
