Old 05-20-2007, 06:40 PM   #1
northerngmc
northerngmc's Avatar
Springs on outside of front brake drums????
I am in the process of taking the front drums off of my 69 GMC to check the brakes before putting it on the road.
On the outside on the drums there is a spring that goes all the way around the outside of the drum. Is this factory as I cannot find any mentioned of it in my service manual?
What purpose would it serve?
Any hints to getting the drums off? I have loosened off the shoes and there does not seem to be a ridge on the drums. I am currently soaking where the hub meets the drum and banging the drum with a 3 lb BFH.
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 05-20-2007, 06:48 PM   #2
Evans
Evans's Avatar
Re: Springs on outside of front brake drums????
I had my front wheels off today for the first time and mine has the springs too....Pretty sure they're factory....I also think the drums are riveted to the hub ... meaning you'll have to pull the hub and drum off together or grind off the heads off the rivets....Hopefully one of the Old Timers has the answers....
Evans is offline   Reply With Quote
Old 05-20-2007, 06:50 PM   #3
71 super
71 super's Avatar
Springs are original. They were put there to help the drums maintain shape/ chatter etc. They can be a pain to get off sometimes- drums not springs- soak hem in good penetrant and use a ball peen or other hammer to tap/rap around the perimeter, sometimes dust and crud builds up and they can be a pain.
71 super is offline   Reply With Quote
Old 05-20-2007, 07:06 PM   #4
Evans
Evans's Avatar
What are the three heads that are on the face of my drums then ??? There is 3 of them in between the lugs ...
Old 05-20-2007, 07:07 PM   #5
northerngmc
Originally Posted by Evans View Post
I also think the drums are riveted to the hub ... meaning you'll have to pull the hub and drum off together....
Yes that is the answer. Pulled the hub and everything came off smoothly.
Thanks....
Blaine
Old 05-20-2007, 07:08 PM   #6
northerngmc
From my experience in the last five minutes I would say RIVETS!
Thanks again....
Blaine
Old 05-20-2007, 07:08 PM   #7
Evans
Evans's Avatar
So they are riveted then ?? Never mind you answered already.. Thank you for being the guinea pig !!!
Old 05-20-2007, 07:11 PM   #8
northerngmc
Left front drum and hub are laying on the shop floor.......
Time to go in the house for dinner.....
Blaine
Old 05-20-2007, 07:18 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
that spring deal was the very first question i posted on here years ago.
Not that that matters.
They helped with cooling, marginally, and also with harmonics too, they helped get rid of a slight ringing that was noticed by very few.
The replacement drums that you'll get today don't have provisions for the spring, nor to adjust the shoes up either.
Old 05-20-2007, 07:22 PM   #10
nplocoman
never finish start another
nplocoman's Avatar
Evans has the answer, you will have to take the front wheel bearings and hub with the drum. If you want to put new drums on, grind the rivet heads off
to remove the hub from the drum.
nplocoman is offline   Reply With Quote
