Old 05-21-2007, 01:06 PM   #1
crm318
Alright Alright Alright
crm318's Avatar
cracked flywheel symtoms
i think that i might have a cracked flywheel. lately i have been hearing this clicking in my engine compartment only when i give it gas. i have looked at everything and nothing was out of order. no loose bolts or anything making contact with anything. then the next time i heard it. i got down by the flywheel and torque converter and that is where the sound is coming from. how much does a new converter cost? if i found one in a parts yard, would that be a bad idea?
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 05-21-2007, 01:12 PM   #2
dave2953
Dave's not here, man
dave2953's Avatar
Re: cracked flywheel symtoms
Do you think it's the converter? I think if you're hearing the noise from there it's the flywheel. I bought my new one for $35 at the local parts house. I'm not sure what a converter costs though.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 05-21-2007, 01:19 PM   #3
jsbgump
Gone Fishing
jsbgump's Avatar
a cracked flywheel sound tinney. crawl under the truck and use a flash light to look around the flywheel bolts and the holes that are punched in the flywheel
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 05-21-2007, 01:41 PM   #4
piecesparts
Parts and more parts
piecesparts's Avatar
If you are going to go to the trouble off buying a new flexplate for your engine. Purchase one that is SFI rated and heavy duty. I went through a couple flexplates on one truck until I got smart and purchased a heavier plate. The torque convertor ballooning is what cracks them, That is by design, so it is not bad.
Old 05-21-2007, 02:07 PM   #5
crm318
crm318's Avatar
what is ballooning? the sound is a high pitch clanking. what tooth flywheel will i need?
1972 Cheyenne
Old 05-21-2007, 02:20 PM   #6
jsbgump
Gone Fishing
jsbgump's Avatar
Should be a 168 tooth. I agree go SFI approved. I havechanged out to stock one in mine before I went SFI
Build Thread
Old 05-21-2007, 03:00 PM   #7
MACO
MACO's Avatar
I had my transmission out to relpace the pump seal and noticed the flexplate was cracked. Very common for these engines. Was not making any noise at the time but it had just started to crack.
1969 C20 Customer Camper CST, 396, TH400, Factory A/C, Olive Green.
MACO is offline   Reply With Quote
Old 05-21-2007, 04:05 PM   #8
piecesparts
As you apply different RPMs and change pressure on the tranny the torque convertor balloons out and changes sizes and thicknesses, that is ballloning on the convertor. That causes the flexplate to crack and make those funny chirping noises from under your truck. So to fight back get a thicker and heavier duty flex plate. (note the name)
Old 05-21-2007, 04:16 PM   #9
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
We bought my Sons truck cheap becase the guy said it had a rod knox. It was just a cracked flywheel, it sounded bad on acceleration
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2019 GMC Diesil Dually. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
