05-21-2007, 06:41 PM | #1 |
Chevy big block motor mount question
The Frame mounts have an oversized opening, I need to know if a grommet is needed to bolt up to the motor mounts? the 72 truck came with a small block but changing over to a big block.
05-21-2007, 07:22 PM | #2 |
member #16
Re: Chevy big block motor mount question
Do you have the 68-72 big block eng mount brackets with the big hole? If so they use a different mounts with a rubber pad on both sides of the frame stand.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
05-21-2007, 07:33 PM | #3 |
That's correct, the 72 big block frame mounts with the 1 1/4 inch opening. Where would I find those motor mounts?
05-21-2007, 08:22 PM | #4 |
member #16
meant to say 68-71. the 72 mounts are like the 73 and newer. I think some of the board vendors will have them, but prepare for sticker shock. There is a FAQ article on Using different big block mounts.
http://67-72chevytrucks.com/vboard/s...d.php?t=122645 http://67-72chevytrucks.com/vboard/s...d.php?t=128765
05-21-2007, 09:38 PM | #5 |
Thanks John I found the right mounts at Truckandcarshop.com
05-21-2007, 10:34 PM | #6 |
18 Till I Die
You can make 1/4" thick square washers and grade 8 bolts and it can work that way also.
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... |
05-22-2007, 12:08 AM | #7 |
Junior Member
72 is unique to itself. Please for your sake talk to BIll at Vintage CHevy Trucks before you buy.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
