Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 05-21-2007, 11:14 PM   #26
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: LFD's Project Traizer 2WD closed cab.
Originally Posted by krue View Post
Trazer, unless it's a Trimmy.
LOL
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 05-22-2007, 12:52 AM   #27
Rokcrln
Rokcrln's Avatar
Originally Posted by onetonk5 View Post
Thats the one pictured in post 12
Pretty bad ass
But the choped top looks out of proportion
Unless it had a pint job it is not the same one.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 05-22-2007, 09:15 AM   #28
raggedjim
raggedjim's Avatar
Kevin
LFD Inc.
I agree, they are 2 different trucks, both are nice though.
Kevin, good luck on your version, Rg
raggedjim is offline   Reply With Quote
Old 05-22-2007, 07:22 PM   #29
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by raggedjim View Post
How bout Buttera/Coddington's version?
http://www.truckinweb.com/features/0207tr_custom/
Rg
They ruined that truck. Body lines are all jacked, front end ugly without a bumper, wheels are tasteless, chop makes it look out of proportion, etc. They took a lot of the styling cues that make these trucks look good and deleted them. To each his own, I suppose...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 05-22-2007, 09:26 PM   #30
72CSTC5
72CSTC5's Avatar
I have been off of the board the past couple of days...busy. I was scrolling down and thought the same thing as VT, shorten the truck frame and graft the bedsides to the truck and save the Blazer. Heck, you could chop up another LWB for that matter. Good luck with the build.
72CSTC5 is offline   Reply With Quote
Old 05-22-2007, 09:31 PM   #31
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I COULD NOT HAVE SAID IT BETTER....
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 05-23-2007, 09:47 AM   #32
raggedjim
raggedjim's Avatar
It's not one of my favorites either, I think changing the wheel well openings was a mistake and I'm not a fan of chopped tops. But there are some things they did that I like (dashboard, the wooden bed, door panels, seats, etc) and the quality of the work is good.
I have a hard time with the idea of a hard top blazer, kinda makes them like the old Ford unibodies, but I also think people can build their trucks the way they want to. I'm sure Kevins version will be much more tasteful!
Rg
Old 05-23-2007, 10:41 PM   #33
rancid
rancid's Avatar
Originally Posted by WORNBRAKES View Post
I will also be watching. You do some great work. My dads friend that I grew up around has done this to several 4wd blazers in SLC but I have not seen a 2wd one. I atached a few pics of the 4wd. I will be watching your build.
you know danny huh.
rancid is offline   Reply With Quote
Old 05-23-2007, 11:52 PM   #34
SCOTI
SCOTI's Avatar
Here's a funny story: The last owner of that snubbed truck went up against the Silver 69 (or 70) short step w/the custom stretched cab & homemade bed @ the Ft.Worth GoodGuys show a couple years ago.
He wasn't real happy that the silver short-step was picked as the better of the class they were in because in his opinion..... "they weren't in the same class..... they weren't in the same stratosphere...." because his Boyds/Lil-John/Johnsons HotRodShop creation was soooooo much more.
I mentioned it wasn't about the amount of money or the # of modifications done..... it was the overall 'feel' of the truck as perceived by John Q. Public (not Mr. Barret Jackson).
He indicated I was naive in my thoughts.....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-24-2007, 09:33 PM   #35
jkade
jkade's Avatar
I am not much on the wheels either but they had to use a wheel with no offset because it has c4 suspension front and rear.
jkade is offline   Reply With Quote
Old 05-26-2007, 12:10 AM   #36
WORNBRAKES
Originally Posted by rancid View Post
you know danny huh.
I do. I have not talked to him in a few years. Do you know him? Do I know you?
Mario and Mandy
Hughesville, MD 20637
69 C10 305/350
71 K5 Basket case
75 K10 Rescue **Parting out**
77 MG Midget **Parting out**
15 6.7L Cummins
WORNBRAKES is offline   Reply With Quote
Old 05-28-2007, 01:05 AM   #37
Rokcrln
Rokcrln's Avatar
Well not much progress to show you all but for me to get things done around here to get it in the shop was alot of progress. Now it is that much closer to starting the rust repair work and quarter panel work. Then once that is done then I will start on the cab section. I feel it is better to repair all problem areas before you go changing and modifying things. You end up with better work and less hassel in the end. Also this is the first time using the wheel dollies I got last month just for this build so I can roll it around to work on it and into corners when I am not. They are rated for 2500lbs each and were about $260 for the set from Summit racing.
Kevin
LFD Inc.
Old 05-31-2007, 05:10 PM   #38
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Kevin,
How easy is it to roll?
Can u do it solo?
Craig
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 06-01-2007, 03:09 PM   #39
Rokcrln
Rokcrln's Avatar
Originally Posted by LUV2XCLR8 View Post
Kevin,
Can u do it solo?
Craig
Yes it is a one man job but you do have to watch out for the cracks in the floor. My shop was built in 1915 +- so the floor is not all that great but still works just fine.
Kevin
LFD Inc.
Old 06-25-2007, 12:57 AM   #40
Rokcrln
Rokcrln's Avatar
Well just an up date on project Trazer. It has been ready to start now for about a month but life keeps throwing curve balls at me right now. First my (1915) shop wiring finaly gave up one leg of its 220 and I am working with PG&E to get my 400amp panel hooked up. The new panel is ordered and the electrician is ready to go as soon as it shows up. Then last Thursday I decided to replace the sink from a duel basen to a deep single basen for washing Taylor when he gets here. Long story short it turned into a full out kitchen remodel due to dry rot and cabnets that fell apart as soon as I touched them. Well the kitchen is almost done now (thanks to Dad being retired and giving me a hand) I will be staining cabnets in the morning, grouting the counters and getting ready to put in the new floor.
So I am really hoping to get to the blazer in the next few weeks or so if the owner still wants me to do it
Kevin
LFD Inc.
Old 06-25-2007, 07:39 AM   #41
msgross
msgross's Avatar
wow, you do more in-between jobs than most of us do for jobs!
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 06-25-2007, 06:35 PM   #42
72CSTC5
72CSTC5's Avatar
Hmmmm, curve balls huh? Good way to put it. I have had my fair lately as well. Good way of putting it. Keep us updated.
Old 06-25-2007, 09:00 PM   #43
mkundo
Kevin,
I'm a patient person. 1001, 1002, 1003. :-)
Dan
mkundo is offline   Reply With Quote
Old 07-28-2007, 11:17 AM   #44
Rokcrln
Rokcrln's Avatar
Lets get this party started!!
Today I will be kicking off "Project Trazer" with a fire wall shave. The Owner (mkundo) came over and we walked over teh build and made a parts list and got our game plan all planned out.
Here's what we came up with. For starters I am going to get teh fire wall shaved and teh gutter molded off as well. Then I will get the body all set and shimmed so our door gap is just right then I will weld in a full body cage so I can start cutting everything out that needs replacing. Once the old metal is removed (pass quarter panel, all rockers, inners, kick panel, drivers quarter lowers and dash) then it will head over to teh media blaster to get stripped and sealed before comming back for the rebuild process. This way we can clean and seal as much as posible to help this build last along time after it leaves my shop. After all the metal is replaced then I will start on the grafting of the truck cab roof. I wil post some pics tonight when I get some progress made.
Kevin
LFD inc.
Old 07-28-2007, 12:29 PM   #45
bouncytruck
SKINNY TIRES RULE!
So, we can expect pictures at the end of the day?
bouncytruck 1972 K5
Old 07-28-2007, 10:48 PM   #46
Rokcrln
Rokcrln's Avatar
Well here is the first installment. I got the first stage done today and I will do the gutter and the heater notch fill after it has been blasted and sealed. I also removed the clutch bump to smooth things out a bit more.
Kevin
LFD Inc.
Old 07-28-2007, 10:58 PM   #47
Rokcrln
Rokcrln's Avatar
Here are a few of teh other problem areas I will be getting to after the body is shimmed and braced.
Kevin
LFD Inc.
Old 07-29-2007, 12:18 AM   #48
bouncytruck
SKINNY TIRES RULE!
What are you going to do with the gutter? I ask because I am clueless about how things like that are removed.
bouncytruck 1972 K5
Old 07-29-2007, 12:30 AM   #49
Rokcrln
Rokcrln's Avatar
This one will be a simple 90* cap off with a thin strip of 18ga sheet metal. I do not remove teh gutter but instead I cap it off. If you want to see the total bomb of gutter shaving look up project "Lemod Drop" and check that one out.
Kevin
LFD Inc.
Old 07-29-2007, 07:39 AM   #50
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Keep em coming
