Old 05-21-2007, 08:15 PM   #1
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
correct valve cover install.
I need to know if this is the correct way to install valve covers (see pic). That’s the way I took the off but the clips on the drivers side threw me, thinking they may not have been correctly installed.
Oil fill & PVC on drivers’ side, and breather vent on passenger side. Is this correct?
Thanks,
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 05-21-2007, 08:28 PM   #2
Lated
Lated's Avatar
Re: correct valve cover install.
That's the same way mine are on my 305 but next time I pull them off I'm going to swap 'em. I'd rather have the oil filler closer to the front so it's easier to get too. It may mean a longer hose for the pcv valve but I think it's worth it.
“If you don’t have time to do it right now, how will you ever find time to fix it.” - author unknown
'70 SWB Step-Side (More rust than metal)
Lated is offline   Reply With Quote
Old 05-21-2007, 08:36 PM   #3
Sport/Truck
Sierra Grande Club
If you do this, cant you just run the PVC to the same location? (it will still be in the front).
s/t
Old 05-21-2007, 08:39 PM   #4
Lated
Lated's Avatar
good point
Old 05-21-2007, 08:44 PM   #5
Sport/Truck
Sierra Grande Club
I was assuming you were going from side to side with the exchange (not just flipping them). You can’t really flip them anyway because they lean a certain way.
Would it look too weird if I switch sides? Anyone else done this?
s/t
Old 05-21-2007, 10:53 PM   #6
Imacarguytoo
You can flip them. Just get a longer hose
'67 C20 Lwb 350 4-Speed
'01 Chrysler Concorde LXI (wifes ride)
'91 Gmc Suburban 3/4 2wd 454 Tbi
'51 Jeep Cj3a "Willys" 350 V8
Imacarguytoo is offline   Reply With Quote
Old 05-21-2007, 11:27 PM   #7
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
I swapped mine so that the oil filler cap would be in the front. I went from side to side. Oil filler cap used to be on drivers rear. Works a lot better.
esll.
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
Old 05-22-2007, 01:07 AM   #8
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
You can flip them from side to side I have done it many times for the same reason.
AND no you can't just flip some valve covers like yours, s/t and keep them on the same side,you are correct that they are canted over to the intake side.
Most but not all aftermarket valve covers can be fliped any which way you want as they are not canted like yours are.
RJ22...
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
