Old 05-21-2007, 10:02 PM   #1
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
SBC AL Intake Sweet
I have a very nice Weiand manifold that fits a small block chevy pre 87 heads with out modification.
87-92 heads can fit with modification to the center 4 mounting bolts.
This manifold looks to be new. It has been mounted on an engine - hence it still has the gaskets attached to the bottom. However the bottom and inside are clean enough to eat off of!
This is a cool manifold - the center plenum divider can be used, removed or modified to make a drop split plenum.
The intake is painted chevy orange with some peeling in a few spots.
Up to 19 more dyno-tested horsepower.
These 360 degree Weiand X-CELerator single plane manifolds make their power in the 1,500 to 6,800 rpm range, which makes them the ultimate manifolds for high-performance street, drag, marine, and Oval Track engines. The carburetor mounting pad is designed to accept all current aftermarket performance carburetors, and includes an open-style plenum for increased flow. Best suited to engines equipped with aggressive camshafts, headers, and high-output ignitions, these intakes are sure to put a smile on your face.
These sell $129.95 + 10.95 handling from Summit.
I would like $50.00 plus the ride.
Paypal (no credit cards please), money order would work as well.
Please respond within the ad so we know who is in line.
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 05-22-2007, 06:50 AM   #2
muddyole 69
Re: SBC AL Intake Sweet
sold pm me your info and thanks Mike
hav'n fun be'n me
muddyole 69 is offline   Reply With Quote
