Best shocks for a 3/4 drop?
![]() I need new shocks and, since I have a 3/4 now, want to make sure I do the right thing when replacing the old stock ones. What's the recommended set-up? Do I need to relocate the shocks? Are there special shocks to order when you are lowered? Any and all info would be appreciated. -- mark Pic below just because I like seeing my truck ![]()
1970 C10 ![]() |
Gone Fishing
Re: Best shocks for a 3/4 drop?
I'd go with the shock relocater kit and the KYB shocks from ECE
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop ![]() 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
It Is What It Is,,,,
I went with the Cal-Max from DJM,, good ride,, I like them, and NO relocatation of the shock either.
*79 C10 Short Box ST8 6 bang'r * *Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT *__--__* 79 C-10 project* .........................__ ..............._____ l __\___ ..............|_(O)_ |___(O) ] FAQ INDEX Thread The Kulture ![]() My Rat Den ![]() |
Can you all educate me about relocation: What's the reason? Is it mandatory? How hard is it to do? Etc., etc. Of course, I could go look this all up. But I am laaaaazy.
1970 C10 ![]() |
relocation is easy for the rear shocks and the reason its done is to correct the angle of the shock to get the most out of what you're paying for// i went with the kbyshocks also the rear relocator
kyb's and relocator from ECC here too. simple bolt on.
So only the rears need relocating then?
1970 C10 ![]() |
67-72 Addict!
Yes, only rears need relocators but you are borderline at 4" drop. The kit is the best deal if you decide to use the relocators. If you decide to buy shocks only, you can order KYB shocks from Advance Auto parts (with free shipping) cheaper than places like ECE.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads Last edited by 70c10; 05-22-2007 at 07:51 AM. |
Thanks 70c10. I think I'm going with just the shocks since I'm only a 4" drop. Can't say how much I appreciate the responses/advice from all of you -- thanks!
1970 C10 ![]() |
