Old 05-23-2007, 03:30 PM   #1
76bonanza
76bonanza's Avatar
tach question
My tach has stopped working I also just swapped my old hei for a new hei. But that was 2 weeks ago and the tach just quit today so not sure if they are related. I check all the wires they seem good. But I do not know what the signal wire should read mine reads like 13.68 and it is in constant change in that area I assume that is how it works? Anyone know what the signal wire should read?
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 05-23-2007, 04:33 PM   #2
hyarbour
Re: tach question
It would change with engine speed, even at idle there would be some fluctuation. Try setting you meter to read AC or Cycles (hetrz) would be even better. What might have happened is the connection in the HEI plug slipped while you were putting it in and finally lost contact.
hyarbour is offline   Reply With Quote
Old 05-23-2007, 05:34 PM   #3
76bonanza
76bonanza's Avatar
Re: tach question
But if I read voltage at the tach from the signal wire can I assume it is not the dizzy but the tach?
1968 c10
lowered 3" 4"
Old 05-24-2007, 10:08 AM   #4
hyarbour
Re: tach question
Most likely, that or the tach's ground came loose. Having a cheap tach for test purposes would be handy.
