Dude...I'm a CHICK
Dash Pad
Some one please refresh me.. was there something tricky about removing the dash pad in my Burb... surely it cant be as easy at it looks....??
thanks junk
~*~*~*~*~*~*~*~*~*~*~*~*~* "The unexamined life is not worth living" -Socrates ~*~*~*~*~*~*~*~*~*~*~*~*~* '71 GMC Suburban 4x4 |
Re: Dash Pad
im not sure if its the same as the c-10's i hope it is so i dont look like a jackass, but after the phillips screws are taken out underneath the dash are some little screw off washers, there shhould be about 5 all along the dash.
Roadtrip!
![]() Join Date: Feb 2003
Re: Dash Pad
Jodie, after the screws are out, there are 7 speed nuts from the back. Best thing is get the dash gauges out, and the glove box liner. There is one at each end that are kind of tricky to get to. They are 3/8". There will be one above the radio also... Good luck, Eric
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
its all about the +6 inches
Re: Dash Pad
the 2 end ones are 5/16 IIRC
And jodie, I can't remember if you have A/C or not... but if you do... be prepaired to have fun. |
Re: Dash Pad
after reading all that im glad mine was replaced when i got it
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
Dude...I'm a CHICK
Re: Dash Pad
thanks so much!!! I have AC but its AMA aftermarket under the dash. Thats comming out too. Thanks guys, I can be a little more prepared now,
take care junk
Licensed to Thrill!
Re: Dash Pad
What's really fun is when you have UNDERDASH A/C, radio, electronic A/C controls, full ductwork and an alarm system crammed underneath there, and you have to put that sucker back on.
DLB |
Saving 1 truck at a time!
Re: Dash Pad
Reinstall with contact cement and hope for the best...LOL! I just installed a new one in the rat rod and decided that it did not need nuts on the back side at all...the misalignment and friction on the studs keeps it in place just fine. I know this goes against all common intuitioin but in time I will forget that I did not put nuts on it and if it falls off in my lap it is not going to create a very big problem.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
Re: Dash Pad
mike... I've always done mine the same way.
Re: Dash Pad
Yeah...if your passenger wants to grab onto things and pull and mess with the truck...I just slap them...LOL!
