05-24-2007, 10:54 PM | #1 |
Finally some pictures of the new project!
So I finally found the USB cable for my camera, so I figured it was time to post up.
Specs: 1971 K20 350ci with a few leaks 4 speed w/granny first Dana 44 big hub front Eaton rear 4" front springs with rear blocks Crooked 3" body lift soon to be removed Nasty interior with seats from hell Random spare tank bolted loosely in the bed?
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
05-24-2007, 10:56 PM | #2 |
Re: Finally some pictures of the new porject!
It says '70 on the windshield, it also says $1500, neither is correct (I paid $1100).
05-24-2007, 11:06 PM | #3 |
Sierra Grande Club
That thing looks big!
FWIW someone said before that those air cleaners can catch on fire, and not to use them. s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
05-24-2007, 11:16 PM | #4 |
thats a frightening truck ---- to a prius driver
05-24-2007, 11:19 PM | #5 |
That thing's big....I'd remove the body lift too,I don't like them on any vehicle.
05-24-2007, 11:29 PM | #6 |
Re: Finally some pictures of the new project!
Thanks fella's. When I said it was the "Super Redneck" edition, I wasn't kidding!
Yes, the air cleaner is gone and I will be getting the body bolt and bushing kit from GMC Paul's on payday to replace the body lift with new hardware. The only rust is in the drivers rocker and there is a smallish dent in the rear passenger bedside. The drivers door will be replaced soon and I think I can pound out the drivers fender. I am waiting on the carpet kit, then I will have everything to start the interior. I have a lot of wiring to do in the cab and the engine, that will be a slow process. I hope to have it on the road in a few months. It will be a long process, but I think it will be cool when it's done. <edit> I need to get a shot of the bear face rattle canned on the hood too.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 Last edited by jimmydean; 05-24-2007 at 11:31 PM. |
