Old 05-25-2007, 03:22 AM   #1
mexgrhd68
mexgrhd68's Avatar
Angry leaky holley intake manifold
I have a 68 chevy with an 83 305 from a monte carlo, I recently installed an holley aluminum intake manifold and it leaks like crazy . Should I have put somekind of thread sealer on the bolts? It's torqued down and it just leaks like crazy. Intake isn't cracked or anything like that. To top it off, it just made my shiny intake look NASTY!!
mexgrhd68 is offline   Reply With Quote
Old 05-25-2007, 03:25 AM   #2
AR15DEFENSE
Resident Absorber
AR15DEFENSE's Avatar
Re: leaky holley intake manifold
oil, coolant, or vacuum?
The best offense is a better DEFENSE!
AR15DEFENSE is offline   Reply With Quote
Old 05-25-2007, 03:40 AM   #3
mexgrhd68
mexgrhd68's Avatar
OIL
Old 05-25-2007, 03:53 AM   #4
GREASEMONKEY72
GREASEMONKEY72's Avatar
is it leaking around the middle bolts and puddling on the intake?
if so pull those bolts, clean them and wrap some teflon tape around them and put them back in and problem solved, did that with mine and hasnt leaked since
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 05-25-2007, 06:26 AM   #5
cdowns
cdowns's Avatar
thread sealant is a must on intake manifold bolts thats why they say so in the service manuals
Old 05-25-2007, 06:53 AM   #6
70c10
67-72 Addict!
70c10's Avatar
Mine leak too. I've tried the liquid thread sealant with no luck. I'll try the tape.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 05-25-2007, 08:46 AM   #7
Billla
Billla's Avatar
I'm not a big fan of Teflon tape on these bolts as they protrude into the coolant passages and the cam valley. You do not want loose Teflon tape running around in the engine...
Billla is offline   Reply With Quote
