Vacuum line from carb to?
There is a vacuum line that comes from the base of my carb and goes through the firewal and under the dash - does that assist the heater/ac controls? When I have it hooked up, I hear a hissing noise from under the dash, so I'm thinking I have a hole in the line under there somewhere.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
Re: Vacuum line from carb to?
not certain, but if your truck has A/C there may be a vacuum reservior to actuate the mode doors, on gm cars atleast there like a 6" ball under the hood, but ive never seen where there at on the trucks
Just follow the line and plug the end -no hiss -truck will run better (idle speed will slow down when you stop the leak)
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
Not sure what year you have but if it is factory air you will see a vacuum resovoir on the airconditioning housing above the passenger valve cover. One end runs to the "T" on the back of the intake manifold and the hose out the other side runs to the vacuum switch "top lever" of the heat/air controls. The vacuum switches can go bad and leak. attached is the vacuum diagram and a picture of a '72 vacuum canister.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper 72 bug(the better half's) under reconstruction 2009 HHR aqua blue 71 GMC k20 350/sm465 2009 Chevy hd3500 6.6 Victory Red crew cab dually Dave & Jeanne |
