a quick favor.
could you guy's with clutch fans do the boatpuller a favor?next time your under the hood grab your fan and see how much play's in it.if any.mine's able to wobble more than i would think is normal.but,hasn't started making racket yet.i got a couple of out a town cruises coming up and thought i'd replace it while i have time.if it's bad.
" Never look up a dead dogs butt." ![]() |
STILL PLAYS WITH TRUX
Got rid of mine along time ago.
But im gonna tell ya that any play isn't good id'e replace it don't take a chance cuz you know when it let's go it's gonna be when your on the road and it will take out the rad, fan belt, tranny cooler lines, who know's. I don't think there that expensive maybe 40 bux if that! It's cheap insurance if ya ask me. Last edited by 87 STEPPER; 05-19-2007 at 01:54 PM. |
yeller
Re: a quick favor.
Just went out and checked mine...no play or wobble in it. Mine is "new", meaning I ran it for one year eight years ago...before I tore the truck down.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
Dark Heart Motorsports
Re: a quick favor.
I can free spin mine
How Deep Can YOU Bleed..? 1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter 2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD! |
Bulky
Re: a quick favor.
I just checked mine. No play side to side does not rock.
They are easy to get to and not too expensive (less expensive than a radiator). If there is any doubt in your mind, swap it out.
2016 Silverado 1930 Model A Hot Rod 1923 Ford A/SR Altered - Injected 409 1982 Honda CB900F Super Sport Dad's 1970 GMC 9' Stepside Dad's 1969 GMC Custom Camper |
What Hump?
Re: a quick favor.
Replace as soon as you can, it'll play havoc on your waterpump which could cause it to leak.
Lil red 86 c-10 99 Sub 78 Camper Special w/ 454 |
Re: a quick favor.
thanks guys,kinda what i expected...off to the parts store tommorow.
Re: a quick favor.
I had one that freewheeled like crazy. You could just spin the thing. The truck NEVER overheated with it though. Seems like it spun just enough to keep things cool. Nice and quiet too.
I did replace the clutch, and everytime I took off from a stop, I would hear "WHHOOOOOSSSSSSHHHHH!!!!!' and feel the motor loaded down. Sound like a cross between a hoover and a kenworth. I had enough of that crap and stuck a flex fan on it. Last edited by Pyrotechnic; 05-19-2007 at 10:25 PM. |
#9 | |
Until Seventy Times Seven
Re: a quick favor.
Lately, once in a great while I hear a very slight whine/grind coming from under the hood. But, it doesn't last long enough for me to find out the cause. So, your thread had me check under the hood. Even before tugging on the fan clutch, I noticed part of the rubber seal separated and sitting on the rear of the shaft. And, of course, it had play. Today, I fetched a Hayden fan clutch for 'bout 30 bones. ![]()
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
Re: a quick favor.
HEY BOAT!!
Get a new one... I had one of the explode and sent schrapnal through the hood of one of my old trucks... And then it had the nerve to eat my radiator/belts and cooler lines too!! ![]() ![]()
-John II "A Little's Good! A Lot's Better! & Too Much is Just Right!!" -1978 Chevy C10 Stepside 350/4sp/12 bolt -1967 Nova 2dr HT & a couple others... ![]() |
Re: a quick favor.
Better make sure it's the clutch fan and not the pump.
I had an S-10 with a noise up front. Thought it was the clutch fan. Replaced it with another used one. It too had a little play. But, it turned out the pump was going bad. When I put the new pump in, I used the original becuase the used one was off an astro van and the there was a difference between the rotation of the pump (surpintine belt) Make sure when you have the direction correct if you use one from a different application. The pump and fan will be different if it's a surpintine belt vs. the conventional style. It's just a thought... |
#12 | |
Re: a quick favor.
I got a chance to replace the fan clutch a couple of days ago. Took 'bout a half hour from start to finish. Used a 1/2" Gearwrench, 1/2" socket and torque wrench. Four nuts and four bolts later, I had it done. The last two pictures show the broken seal and some fluid leakage. ... Noise is gone too.
#13 | |
7000 #'s of american IRON
Re: a quick favor.
Re: a quick favor.
thats weird box,i bought the exact same clutch used the same tools and took about a half hour.it did help, that i'd had evey belt,pulley,bracket and accesorry on and off about 42 times this winter,when i switched my a/c compressor over to the passenger side during vintage air install.i'm lovin it now though...........first big test this week,when weather dude says it's gonna be 90.......... i'm gonna do a future mod.electric fan ,when i stick in a new zz4.
" Never look up a dead dogs butt." ![]() Last edited by boatpuller; 05-28-2007 at 11:40 AM. |
#15 |
glamoros piece o' lowlife
Re: a quick favor.
I have the stock 7-blade fan bolted to the water pump through a solid Hayden spacer - no clutch whatsoever. My truck needs it tho, having no shroud an a small radiator can be quite the pain when you're stuck in traffic at 90F heat.
The more I drink, the more I drink, the more I drink... diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express |
