Stupid tool question
So I got air tools for the first time, and I attach a socket to the 1/2" impact wrench. Now the socket won't come off. There was a little c-ring thing on the tip, right after the square part that the socket fit onto. It was tough to get the socket over the c-ring. Now it won't go past it to come off. Was the c-ring supposed to be an o-ring and not loose? What else could cause this? I have no other to compare it to right now.
1970 C10 ![]() |
Designated A-hole!
Re: Stupid tool question
If it's just the ring your gonna have to bump the socket with something (another socket etc). If you're using an impact socket and your impact has the pin look on the wrench end of the socket for a hole, insert a small screwdriver or something similar to push the pin out.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
ive had that problem with new ones to but it broke in after some use and theyre fine now
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
that clip is on there to keep the socket from coming off just take a screwdriver and pry the socket off. it should be snug and will probably loosen up with time and use.
i type slow... what krue said. Last edited by slt0066; 05-27-2007 at 09:29 PM. |
Ta-Da!! We have separation. This board
1970 C10 ![]() |
youre a magician now
,Clint LOUD PIPES SAVE LIVES ![]() 69 C-10 short stepside 406 sbc, 02 YAMAHA WR250F, 07 SUZUKI SV650S, 81 Grand Prix 355 sbc, 81 XT 500 YAMAHA |
![]() (I'm due for a trip to Harbor Freight to downgrade)
1970 C10 ![]() |
Designated A-hole!
The ONLY problem with HF impact sockets is they're a little tight to start with, until they get some wear on them. Pull the nut (or bolt) ALMOST all the way off, pull the socket off then finish loosening the nut or bolt.
Zappaphile!
And a little tip for you (From someone who has inherited Air Tools older than our trucks that are still running great)
DONT FORGET TO OIL THEM AFTER EVERY USE. If they are going into longterm storage (year or more), oil the hell out of them. I rarely fire up my 1 In impact, which is about 50 years old, but it still runs like new.. Have fun.
1969 C20 LWB Camper Special - The Beater.. 1998 Cheyenne V6 - 4/6 Drop - For The Son |
#11 | |
1970 C10 ![]() |
Junior Member
ive heard dont use chrome from sources other than sears. *shrug* i always assumed it was a safety issue due to composition materials and heat treatment used to make the socket?
If it's Craftsman and it breaks...they replace it right?
They don't have to know that I had a three foot cheater pipe on that breaker bar. ![]()
1978 Chevrolet Silverado 3/4 ton 400 small block. 2000 F-250 Powerstroke 2002 GMC Yukon Denali XL |
MOVE OVER
I heard that the chrome can shatter? not sure if thats right, and I have used them in the past, but bought some impact sockets as well.. just to be safe..
No matter where you are..... There you are... Buckaroo Banzi |
#15 |
the thing with chrome sockets is if they crack the chrome will flake off and if you have your hand on the socket it'll cut up your hand really bad, and a note warrantys are void if you use on impact, trust me
