Dave's not here, man
Hydraulic Brake Light Switch
Anybody running one? I'm trying to figure out how to plumb one of these and I'm not sure where to get the correct fittings. I need to go from the SAE brake lines and "T" into a 1/8" NPT for the switch. Any help would be appreciated.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
member #16
![]() Join Date: Dec 1999
Re: Hydraulic Brake Light Switch
The only way I can think of is to use a 1/8" npt T and use a 1/8" thread fitting to adapt to the inverted flare brake line in each end of the T. I dont remember seeing a brake line T with a 1/8" npt port.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ Last edited by john; 05-29-2007 at 05:09 PM. |
They make a brake line T with an 1/8" port. Bought mine from local parts house....in their brass fitting drawers.
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
Thanks for the help; I'll check tomorrow and see what I can come up with.
