Old 08-14-2001, 07:15 PM   #1
Graham
Post DRL
Does anyone know where the DRL module (diode) is located on a 1997 Chevy Silverado P/U???????????????
Graham is offline   Reply With Quote
Old 08-15-2001, 04:41 PM   #2
ThreeQuarter
ThreeQuarter's Avatar
Post
No, I don't know that there is a DRL module, per say. If you're just looking to disconnect them there is a fuse that you can pull...I forget which number.
'72 GMC C2500 Longstep 350/SM465/4.10
'92 Chevy K1500 XCab LWB 350/700R4/3.73
Aggieland, TX
Ben
'68 Chevy C10 Custom LWB 327/TH400 2nd owner
'94 Ford Explorer XLT 4wd
'25 RAM 1500 Laramie 4wd
ThreeQuarter is offline   Reply With Quote
Old 12-01-2002, 11:23 PM   #3
ross96ls
Anyone else have any other ideas or experience with this one?
We just picked up a 1997 Chev Silverado Extended Cab 4x4 this weekend. It does have DRL's as well, and we would like to know how to disable them.
There is a fuse in the drivers side door jam marked DRL/Fog, but removing that fuse doesn't do a thing.. Lights still come on.
Any info would be great.. Thanks!
ross96ls is offline   Reply With Quote
Old 12-06-2002, 09:15 PM   #4
Piston
Piston's Avatar
Very common for these to go out actually. The module is nothing more than a diode incased in a heat sink.
The module is located just below the column on the right side. If you lay underneath the dash (drivers side) you'll see the bottom of the module. It's a black finned box with what looks like Sand in the bottom hole. These things overheat and short out. They simply slide out of the bracket or you can unbolt it. The new one comes with a mounting bracket but I've found it easier to just remove the bracket and use the vehicles bracket.
Curious, why disable them?
Piston is offline   Reply With Quote
Old 12-08-2002, 12:56 AM   #5
ThreeQuarter
Piston, I had my first truck with DRLs about four years ago. I found it very frustrating that I couldn't flash my lights at anyone (for whatever reason). Also, I don't think having your lights on so that people can see you a 1/2 mile away helps any--you can't have a collision from a 1/2 mile away. Those are my reasons, anyway.
Ben
