Old 05-23-2007, 11:06 PM   #1
Chrisneedshelp
Rear Window Wont Go Down Fully
I've got an 88 K5 Blazer and the tailgate window will only go down halfway.The window motor works great and not too long ago the the sashes and channels were replaced.It doesn't appear that anything is blocking it from going down.Does anyone have any idea of what might be going on?
Thanks,
Chris
Chrisneedshelp is offline   Reply With Quote
Old 05-25-2007, 10:21 AM   #2
blazer2007
Re: Rear Window Wont Go Down Fully
I know on mine there was a safety catch, child proof thing,in side somewhere can,t remember where but if you open up tailgate and look carefully should see it ,hope this helps
blazer2007 is offline   Reply With Quote
Old 05-25-2007, 10:28 PM   #3
I went over all the electrical stuff and ended up with needing the guides in the tracks replaced.The glass goes from straight up to an angle and they hang up.Next,your window won`t go up past that point,if you do get it completely down.
Old 05-27-2007, 02:40 AM   #4
Chrisneedshelp
Still stuck, can't find any "childproof" mechanism.The tailgate doesn't open because of rot (working on that) but I do have the interior tailgate cover off and cant see anything that would stop it.
Old 05-27-2007, 12:13 PM   #5
85 K5
Disconnect the cable from the gearbox and see of the motor and cable turn freely. Mine had a bind inside the cable. ($50-60 at the dealer)
Next, disable the switch so you can run the window up and down with the tailgate open. Leave the tailgate at a vertical position but so that it will not go inside the channel of the top and see if the window will go up and down. These steps should provide some clues.
350 Crate 10 bolt 3.73 2.5 lift 32x11.50 1904 Edelbrock
http://www.oplnk.net/~spirit/K5front.jpg
85 K5 is offline   Reply With Quote
Old 05-31-2007, 10:32 PM   #6
Chrisneedshelp
thanks for all the help.my tailgate is rusting away and will not open.i'm just going to take it off.
