Old 12-07-2002, 11:50 PM   #1
traie8
Unhappy need help with dashboard repair!!!
I have a 72 Chevy C-10 deluxe fleetside with a wound from an idiot previous owner. He filed out the stock radio hole to fit a newer stereo. Now there's a big gaping hole in the dash. I bought a nice replacement AC dash on ebay a while back but my dilemma is this: can I just cut out what I need from the parts dash and weld it into mine if I cut both to match? My dash overall is in a heck of a lot better shape than the one I bought, so I really don't want to remove it completely. Help!!!!!!!!
traie8 is offline   Reply With Quote
Old 12-08-2002, 12:14 AM   #2
ozarkhippie
I did a couple a/c dash conversions. I simply take the dashpad off and cut the dashes there, the dash is perferated there and the dash pad hides the welds. It is easy to change out the whole dash panel this way.
ozarkhippie is offline   Reply With Quote
Old 12-08-2002, 01:06 AM   #3
junkyardjohn
junkyardjohn's Avatar
Thumbs up
IF YOU DO JUST REPLACE THE CENTER SECTION OF THE DASH, CUT THE PERFORATIONS UNDER THE DASH PAD, & VERTICALLY THE THE INSTRUMENT PANEL HOLE & THRU THE GLOVE BOX HOLE. VERY LITTLE SHOWS TO NEED FILLER.
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 12-08-2002, 09:35 AM   #4
racedvl
racedvl's Avatar
I think that you might be able to get more help on the 67-72 message board, so, I'm gonna move this there.
racedvl is offline   Reply With Quote
Old 12-08-2002, 12:24 PM   #5
70c10
67-72 Addict!
70c10's Avatar
Welcome from Maryland traie8. Yes, you can cut the section you need and weld it to your existing dash. You can grind the edges down and feather them out with Bondo. My dad did this on his truck and it looks like new.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
