Old 06-01-2007, 01:47 AM   #1
72Blazerod
72Blazerod's Avatar
How much can a '67-'72 Suburban 3/4ton tow?
Just tossing some ideas around for a tow vehicle for a large travel trailer. Was wondering what a 3/4t Sub could pull. I would like to know what the 2WD and the 4WD are capable of. So all you Sub guys, let's hear it!
Thanks,
Rod
1987 GMC Suburban 1/2 ton 4x4 (Beater)
1998 GMC Suburban 2500 4x4
1972 Olds 442 Convertible
2006 GMC 2500 Duramax Crew Cab (Sold)
1972 Blazer 4x4 (Sold)
72Blazerod is offline   Reply With Quote
Old 06-01-2007, 09:16 AM   #2
72freak
Rottenwood Garage Member
72freak's Avatar
Re: How much can a '67-'72 Suburban 3/4ton tow?
no problem here
72freak is offline   Reply With Quote
Old 06-01-2007, 09:47 AM   #3
Hart_Rod
Hart_Rod's Avatar
Originally Posted by 72freak View Post
no problem here
72FREAK, How long is your trailer and how much does it weigh? I would like to buy one, but I want to make sure I can pull it with my 69 Suburban.
Hart_Rod is offline   Reply With Quote
Old 06-01-2007, 02:53 PM   #4
OldCreek
OldCreek's Avatar
My '72 brochure lists what I suppose to be a Max Trailer weight @ 6,000 lbs and Max GCW @10,500. This was for the C20. It doesn't specifically list the K20.
I suspect with better brakes, tranny, engine that we seem to all aspire to that these numbers could be even higher. Especially, with weight distributing hitches, trailer brakes, etc.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 06-01-2007, 10:25 PM   #5
prairewolf
A post was recently posted by igotachevyor2 (brocure i stumbled on) that is a good read for subs. It says it all better than i can..... I have a 72 3/4 ton sub...
I think with aux. tranny cooler, equalizer hitch on trailer, and good trailer brakes i would be good to go. it has about 131,000 miles on it and shifts about like new. one of the articles posted is dated aug. 1969, the other 1970. kent.
prairewolf is offline   Reply With Quote
Old 06-04-2007, 06:11 AM   #6
prairewolf
thinking it through a little,,,,also Quality 10 ply tires properly inflated. we have work trucks with firestone trans-force tires on, we load the snot out of them and they still run straight down the road. we have slow leaks some times from screws or nails stuck through tread, but rarely have blow outs. nothing would ruin a good camping trip quicker than a pretty tire with a weak sidewall grenading at 65 mph.
kent
Old 06-04-2007, 06:37 AM   #7
A Suburban that is set up to tow can pull anything that you can hook to a frame-mount ball hitch(pull behind).Anything too big will have a pintle hook.It`s up to the individual where within those limits you want to be.
Old 06-04-2007, 07:36 AM   #8
72freak
72freak's Avatar
24'
I think it is 5800 pounds or so.
You should definatley have load range E tires, tranny cooler and trailer brakes.
As mentioned above.....with the correct equipment you can pull what you want!!!
Old 06-04-2007, 05:14 PM   #9
clemracer
I have a 72 3/4 ton with a 350 engine a cam headers and a turbo 400 trans with a trans cooler we pulled a 20 foot enclosed race trailer with a midget 4 wheeler rollaround tool box cabinets in front with a compressor generator and many spares. It pulled the trailer great at 70 on the interstate. It has a weight dist. hitch and trailer brakes and a sway controller. When I first got the trailer I did not have the sway control and the weight Dist. hitch and it needed it.
CLEMRACER
clemracer is offline   Reply With Quote
Old 06-04-2007, 05:58 PM   #10
Hart_Rod
Hart_Rod's Avatar
Thanks for the info. I'm thinking a 20' Airstream would probably be better suited for my 1/2 T Suburban. You don't know where a nice one is do ya? .
Old 06-04-2007, 09:23 PM   #11
IAFF2407
IAFF2407's Avatar
Hart_Rob, try this,
www.airstreamforums.com
oodle.com
IAFF2407 is offline   Reply With Quote
Old 06-04-2007, 11:12 PM   #12
Hah,I knew there must be an Airstream forum.Gotta love those silver twinkies.
Old 06-05-2007, 12:16 AM   #13
Hart_Rod
Hart_Rod's Avatar
Apparently the people that own them, love them a lot. Did you check out the prices?!?!
