05-30-2007, 10:10 PM | #1 |
Intermediate Steering Shaft Plastic Pins?
I pulled out a 3" body lift on my 72. In the process, I had to remove a bolt that the last owner put in the intermediate shaft. I understand that the stock configuration had plastic buttons that held the slip joint in a certain position and would tear off so the unit could collapse in case of a crash. What I'm interested in is how to determine where the stock position is? And I understand why you GM wanted the plastic tabs to break but I don't see what their purpose is? Can I just do without any locking mechanism? If not, does anyone have suggestions on what to use to replace the plastic tabs?
Thanks, Whit |
05-30-2007, 10:50 PM | #2 |
Re: Intermediate Steering Shaft Plastic Pins?
Couple of small body lifts that I did, I just extended the shaft and left it alone after that. I did however goop a small amount of antiseize inbetween the 2. I think if you want to recouple the pieces you could drill completely thru and install a roll pin---but that would not allow a collapse in the event of an unfortunate accident
05-30-2007, 11:11 PM | #3 |
IMHO, there is no reason to replace the pins, because there isn't gonna be any lateral movement in the shaft
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
05-30-2007, 11:47 PM | #4 |
The Older Generation
with brak...
If you wanted to find the stock location I would think you could drill out the plastic in both pieces and put a piece of brass tubing (hobby shop) in there that would hold it in the stock position and still collapse if needed. LockDoc
05-30-2007, 11:55 PM | #5 |
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
05-30-2007, 11:57 PM | #6 |
While they are out..Install a Van tilt column if you have access to one or want on.You have to remove the pins when installing the van tilt anyway
05-31-2007, 01:06 AM | #7 | |
Thanks, Whit |
05-31-2007, 10:56 AM | #8 |
Some trucks had tilt columns originally.When installing a longer van tilt you remove the pins and collapse the shaft so its shorter to accomodate for the longer van tilt.
05-31-2007, 03:22 PM | #9 |
its all about the +6 inches
the column its self is the exact same, it's just the shaft stickin out the bottom. So from the drivers seat... you can't tell becouse the wheel is in the exact same place... unless you opt to move it more for or aft.
The pins, there is no reason in the world to put them in again. The only reason they were there in the first place, was so the shaft wouldn't seperate when the workers were moving them from storage to assemblyline, and when installing them. Once bolted in place, it is physicly imposible for the shaft to extend, or contract, unless major body damage causes it. |
05-31-2007, 03:58 PM | #10 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=191143 LockDoc
05-31-2007, 11:52 PM | #11 | |
Thanks, Whit |
06-01-2007, 12:32 AM | #12 |
the whole reason for the slip shaft on any column is to colapse if you get into a front end collision. Without the slip shaft, the wheel will extend up towards your head, which is already making a bee line directly to the wheel.
06-01-2007, 03:26 AM | #13 |
Got it but I'm currious why GM built travel into both the shaft and the upper joint. Maybe what I'm really asking is if it's normal for the shaft to slide into the upper joint?
Thanks, Whit |
06-01-2007, 05:02 AM | #14 |
The upper joint is essentially a u-joint.
I'm guessing it's to compensate for any chassis flex.
06-01-2007, 07:30 AM | #15 |
So how much longer is the van column compared to the truck column?
Frank
70 chevy lwb c10 454/th400 and a 9" rearend suicide doors, marker light fuel fill, 4" cowl , mini tub |
06-01-2007, 02:58 PM | #16 |
4 inches at the most. Probably more like 2 to 3 inches.
