Old 05-28-2007, 11:23 PM   #1
cstanley
cstanley's Avatar
Help! Can't get original steering arm off!
I installed my 4" Suspension lift this weekend, but i couldn't finish because i couldn't get the steering arm off to replace with the raised one. is there a trick i'm missing? does it take some sort of gear puller or something?
pics of the original still in place...
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett
'72 Blazer Restoration Blog: http://sportchicken.blogspot.com/
cstanley is offline   Reply With Quote
Old 05-28-2007, 11:29 PM   #2
1969k10stepside
Re: Help! Can't get original steering arm off!
Very common problem when installing a lift kit...You can't get the steering arm off.There is lots of thread about that here.Just search and you will find tons of threads with people asking about removing the steering arm.
Here is one thread that might help you.
Link
1969k10stepside is offline   Reply With Quote
Old 05-28-2007, 11:32 PM   #3
cstanley
cstanley's Avatar
thanks. i was so frustrated i didn't even think about searching...
Old 05-29-2007, 11:52 AM   #4
Zoomad75
K5Camper
Zoomad75's Avatar
Based on the frequency of the steering arm question, should we take the one thread that has the most detail and make it a sticky?
It's a common issue to run into when lifting a solid axle GM truck. Might make it easier for the 4wd noobs to find it.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 05-29-2007, 01:06 PM   #5
1969k10stepside
Ok,I threw together a thread with various quotes from members with tips of removing the steering arm.The thread is sticky and located at the top of the page.
Old 05-29-2007, 02:16 PM   #6
cstanley
cstanley's Avatar
sweet. i'm happy to know i can inflict so much drama...
Old 05-30-2007, 12:27 AM   #7
Zoomad75
K5Camper
Zoomad75's Avatar
No drama, just one of those often repeated questions.
Thanks for putting up as a sticky...
Rob Z.
Old 06-02-2007, 07:56 PM   #8
70 net440
Junior Member
70 net440's Avatar
Does anyone make a drop pitman arm to come off the steering box? Seems that might be easier to remove than the steering arm.
63 C10
70 Coronet R/T
67 C10
70 Dart Swinger
71 K10
70 net440 is offline   Reply With Quote
Old 06-02-2007, 08:06 PM   #9
msgross
msgross's Avatar
yep, most kits have that option. I think if you go 6 or 8 inch they recommend both. You should start looking at crossover steering for off-roaders that do 6"+ lifts though.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 06-02-2007, 09:56 PM   #10
cstanley
cstanley's Avatar
well, i finally got back after it today. it only took about 2 minutes! I tried the socket method, but it didn't visibly do anything.
however, a 12lb sledge hitting the arm from the front/sideways did the trick very quickly! see my other post for the results!
