Re: Rear Axle Help
Yeah I've learned that I cannot just replace the pinion. I think i'm just gonna swap out to the 3.73 gears. So there is no set way to get a pinion out? The 3.07 one was bad so I didn't care if it got busted, which it did while beating on it. I don't want to ruin a good pinion if it is still usable. Worst case though I suppose is i'll have to buy a new ring and pinion set.
1978 Chevrolet Silverado 3/4 ton 400 small block. 2000 F-250 Powerstroke 2002 GMC Yukon Denali XL |
Re: Rear Axle Help
Best way I've found is a solid brass drift (or round stock) about 8" long and an inch in diameter. After you have the carrier out and pinion nut and yoke off, place the drift squarely on the small end of the pinion and whack with a hand held sledge hammer or equivalent. Have a buddy nearby to catch the pinion because it'll come out quite quickly when it finally does move. Also, watch the fingers. You'll need them later. Good luck.
69 C-10 SWB Fleetside 454/TH400 (For Sale) http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12 70 El Camino 454 TH700 29 Model A 4-DR Sedan Deluxe |
