Old 06-01-2007, 09:57 AM   #1
FlatBrokeRacing
FlatBrokeRacing's Avatar
How Low can I go...
I should know this already but mainly want to get your knowledge passed to me.
1980 GMC Stepside. I want to know how much I can safely cut the front coils and front bump stops before it starts riding like a goat wagon. I was given some shackles for the rear a while back (they are now installed) and just want to set the front down about the same amount. 2inches.
Thanks in advance for any help...
FlatBrokeRacing is offline   Reply With Quote
Old 06-01-2007, 01:26 PM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: How Low can I go...
don't cut more than 2 coils off. I would try 1.5 coils first
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 06-01-2007, 03:06 PM   #3
FlatBrokeRacing
Thanks CaptKaos,
I thought I could go two rounds but wasn't sure. I might just stick to one and a half.
Old 06-01-2007, 05:01 PM   #4
Malo83
Cruzzzn' Vet
Malo83's Avatar
This how my front sits with 2 cut coils, 1 cut coil is a 2" drop depending on the spring, correct me if i'm wrong but shouldn't the coils be cut as whole coils in order to sit in the spring pockets on the A-arms
15x9 rim
275/50/R15 TA's
John
Malo83 is offline   Reply With Quote
Old 06-01-2007, 06:48 PM   #5
KMK454
KMK454's Avatar
Hm, cutting springs?
I have experience with this on a 91 Camaro... cut 1.5 coils to lower it and after a year or so the car sagged and bottomed out.
The right way was to buy uncut springs that provide the desired lower ride height. Luckily Eibach made some...
Kurt
Instagram: @kurtkphoto
1978 C10 Silverado
1991 Camaro B4C
KMK454 is offline   Reply With Quote
Old 06-01-2007, 07:13 PM   #6
SCOTI
SCOTI's Avatar
Cut 1 coil off & see how much drop you get. It's easier to go back & trim a little more off (& you can't add back on if 1.5 coils are too much).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-01-2007, 09:30 PM   #7
knightlife
Dark Heart Motorsports
knightlife's Avatar
I concur....
How Deep Can YOU Bleed..?
1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter
2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD!
knightlife is offline   Reply With Quote
Old 06-02-2007, 07:23 PM   #8
78chev
78chev's Avatar
Were the springs on the 91 progressive? You can't cut progressive springs.
78chev is offline   Reply With Quote
Old 06-03-2007, 01:29 PM   #9
FlatBrokeRacing
Thanks for everybody's in put. I did a ststic slamm on an old 82 LBF that I had in highschool. (Found out the hard way how not to do it)
I am going to tend to agree on full coils at a time for proper seating.
Malo83,
That is a smooth look you got going there.
I will post some pics of mine as I am doing the front...The rear already has 2in shackles and I have yet to flip the rear. Either way, It will be a road hugger.
Thanks everybody
