Old 05-30-2007, 02:23 PM   #1
RAB38
power steering issues
Has any one had any issues going to cross over steering with thier power steering pump? I am on my fourth pump and it just went bad. I have the gm performace parts serpentine set up and the pump it came with was off of a 90's camaro. That one did not last at all. I replaced it with one for a 89 chevy 1500 4x4, that one started to leak at the shaft seal. I replaced it with a 3/4 one from the same year and it would not steer once it got hot. So this time I put one off of a 1 ton truck and put a cooler on it. This one lasted exactly one day before it went. This time it leaked so bad out of the front shaft seal that it blew oil all over everything under the truck and when I got home it had no oil in the pump what so ever.
This thing has been on the street and not off road, I am at a loss other than buying a PSC hydro assist set up.
Any thoughts or ideas? Am I missing something here?
72 Blazer CST 383 stroker roller, fuel inj, t350,NP205, D60 front, 14b rear, detroit locker, 38 x15.50 mtz's, welds, cross over steering, custom cage,Line X Spray in liner, House of Colors Tangelo Pearl Orange
RAB38 is offline   Reply With Quote
Old 05-31-2007, 07:59 AM   #2
OLDCHEV4X4
OLDCHEV4X4's Avatar
Re: power steering issues
Hmmm...Mabey the belt is too tight. Is the tension adjustable? Mabey a bigger pulley on the pump to slow it down?
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 05-31-2007, 08:41 AM   #3
Mudder
Mudder's Avatar
Ya sounds like a belt tension problem.
Mudder is offline   Reply With Quote
Old 05-31-2007, 09:01 AM   #4
Southedisto
River life......
Southedisto's Avatar
I vote tension problem also.
Southedisto is offline   Reply With Quote
Old 05-31-2007, 10:41 AM   #5
RAB38
The idler pulley shows that it has the proper tension,on the serpentine set up there is no adjustment for tension other than different belt sizes and I am using the one that the setup came with. Any other ideas, what pumps are most people running?
Old 05-31-2007, 10:47 AM   #6
Mudder
Mudder's Avatar
What about the alignment? Is it good and straight with the belt?
Old 05-31-2007, 11:36 AM   #7
RAB38
yes, the alignment is good.
Old 05-31-2007, 09:07 PM   #8
Blue_71
Bloo
Blue_71's Avatar
are you buying used pumps?
some 1 tons have a service bulletien about the factory pump leaking at the front seal
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 05-31-2007, 09:35 PM   #9
trkklr77
trkklr77's Avatar
Location: vacaville ca, because it as far from indy as i can be
are you sure you have them hooked up to the correct ports on the box.
some thing is either wrong at the box or you are seriously getting the ****ty end on the pumps
trkklr77 is offline   Reply With Quote
Old 06-01-2007, 07:28 AM   #10
RAB38
They are remanufactured pumps from car quest, I believe they are A-1 Cardone which is normally a better quality then the others. But maybe not with the problems I've been having. The ports are hooked up correctly, I believe the lines are two different sizes and can be hooked up only one way.
Old 06-01-2007, 07:38 AM   #11
Mudder
Mudder's Avatar
With crossover steering you are using a 2wheel drive box?
Old 06-01-2007, 08:08 AM   #12
RAB38
Yes I have a two wheel drive box.
I have no ideas on what else to check, I am getting ready to bite the bullet and put a psc kit on it.
Old 06-02-2007, 10:59 AM   #13
6869704X4
Just thinking out loud here but, if the belt is too tight why is it killing the pump every time.
I agree with trkklr77. Try another steering box.
Also, what are the condition of your hoses? Any clogs?
Not saying getting four bad pumps is impossible but the odds are pretty high.
The more I learn about women, the more I love my truck.
6869704X4 is offline   Reply With Quote
Old 06-02-2007, 11:32 AM   #14
Mudder
Mudder's Avatar
If the tension is too tight it will tear the seal up pretty quick. Seems to me tho that it would have to be really too tight to do that tho.
Old 06-03-2007, 12:00 PM   #15
6869704X4
What I was wondering was why the PS pump every time instead of the water pump etc. Are the PS pump bearings that much weaker?
Old 06-03-2007, 04:44 PM   #16
vtblazer
vtblazer's Avatar
Are you running ATF in it or power steering fluid?
PSC recommends using ONLY actual power steering fluid in their pumps.
(says ATF is thicker)
Can't imagine that's the problem but thought I'd throw it out there...
How about the x-over linkage, any binding?
vtblazer is offline   Reply With Quote
Old 06-03-2007, 07:51 PM   #17
RAB38
I am running power steering fluid, and the cross over linkage does not appear to be binding.
