Old 06-03-2007, 10:50 PM   #1
h8menow
how my weekend went
so yesterday i fly out to phx. to pick up the burban i just bought. looks great hopped in and started the 425 mile trip home. on the first fill up before we left phx. i checked all the fluids (luckily) no power steering fluid, low coolant and 1 1/2 qts. low on oil. also on the way home i find out the fuel guage and speedo don't work. 2nd stop flagstaff fill up and add 1qt of oil, last stop grants nm fill up and add 1qt. of oil. over all the truck did great, i have a little work to do. in the next month i plan on yanking the motor and replace all the gaskets, install new radiator and hoses, and fixing the speedo and fuel guage. i only spent 150 of gas which i think was good.
h8menow is offline   Reply With Quote
Old 06-03-2007, 11:30 PM   #2
CG
BlahBlahBlah
Re: how my weekend went
You are pretty upbeat considering the problems you had. Were these all expected?
Old 06-04-2007, 07:55 AM   #3
krue
Designated A-hole!
krue's Avatar
It's a good looking truck!
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 06-04-2007, 11:33 AM   #4
h8menow
i was hopeing it was alittle better, but it wasn't to bad. when i got to work this morning we found out it needs a speedo cable and a float for the sending unit.
Old 06-04-2007, 02:13 PM   #5
64GMCHorsepower
Justified!
very nice ride!!!!!!
Chad
1964 GMC Fleetside Shortbed....350/700R4 tranny
64GMCHorsepower is offline   Reply With Quote
Old 06-04-2007, 02:17 PM   #6
shaneschevys
Its always something!
shaneschevys's Avatar
Nice
79 p10 stepvan
72 Short Fleetside
72 Suburban
67 GMC One Ton Flatbed
64 Short Fleetside
57 Chevy 2DR Hard Top
57 Chevy 2dr wagon
65 f*** short fleet
63 C 60 Flatbed
Member of the patina club
shaneschevys is offline   Reply With Quote
Old 06-04-2007, 02:34 PM   #7
Bamm
Cowboy Fan for Life!!!!!!
Bamm's Avatar
Not bad fixes. Did you get a good deal? Welcome to the board from Virginia....................Bamm
1967 ShortBed Fleetside
3/4 Drop 350/700R4
Tilt wheel
18 x 8 Torque Thrust II's
Future mods: All new gauges & wood bed
My Zip is 23002
I ship UPS, USPS
Bamm is offline   Reply With Quote
Old 06-04-2007, 02:34 PM   #8
Pop's72
It's ok to stare...
Pop's72's Avatar
Saw that one on Ebay... Glad to see it went to a good home!
Pop's72 is offline   Reply With Quote
Old 06-04-2007, 08:59 PM   #9
h8menow
so i replaced the speedo cable it broken internally, and i modified the sending unit. tested the sending unit and found it to be good, so i removed the float and gave it a pinch and gas was leaking out of two little pin holes. we couldn't get just the float so i bent the float rod and installed a 2006 gmc truck float. works like a champ, tommorrow i'm going to clean up the rear end, replace the pinon seal, diff gasket and shim the starter.
