06-03-2007, 03:53 PM | #1 |
manual tranny options?
hay i looking into a new tranny, any one got any ideas i was looking at a tremec Tko so i would have a 5 speed with overdrive anyone have much expereince with these or know a good overdrive altenative
,Clint LOUD PIPES SAVE LIVES 69 C-10 short stepside 406 sbc, 02 YAMAHA WR250F, 07 SUZUKI SV650S, 81 Grand Prix 355 sbc, 81 XT 500 YAMAHA |
06-03-2007, 04:06 PM | #2 |
Re: manual tranny options?
NV4500 is what you want if you have big power it its moderate some guys are using the nv3500. here is a good post on the swap http://67-72chevytrucks.com/vboard/s...d.php?t=212959
Hope this helps.
Earl 68 2500 4x4 GMC Burb |
06-03-2007, 04:17 PM | #3 |
i was going to try and keep my manual clutch because i don't have the time or a shop to fab up hydraulic clutch , i live 120 miles from my home and my shop, is there any way to run a manual clutch on an nv4500?
yes i am planning to put power to it so i looking for something that can handle i replaced my fly wheel yesturday and found metal shavings im my trany, alot of metal shavings
,Clint LOUD PIPES SAVE LIVES 69 C-10 short stepside 406 sbc, 02 YAMAHA WR250F, 07 SUZUKI SV650S, 81 Grand Prix 355 sbc, 81 XT 500 YAMAHA Last edited by sodak69c10; 06-03-2007 at 04:29 PM. |
06-03-2007, 04:29 PM | #4 |
Yes Advanced adaptors sells a bell housing that works with the manual clutch set up. I have been thinking about selling my stock nv4500 bell housing and using theres I cant make up my mind if I want the hydrolic clutch under the hood. Ive been trying to come up with a way to hide it under the dash.
06-03-2007, 04:31 PM | #5 |
at a side note over at the deisel place there is a 2wd nv4500 for sale for 200 that is supose to be a good trans I was thinking abought buying it as a spair they sell for between 800 and 1500 on evilbay.
06-03-2007, 04:52 PM | #6 |
http://cgi.ebay.com/ebaymotors/TKO-5...QQcmdZViewItem
here is the tranny i am looking into one like it anyways
06-03-2007, 09:03 PM | #7 |
that is the trans all the guys on the 68 firebird board Im a membor of use. they seem to like it.
06-03-2007, 09:37 PM | #8 |
its all about the +6 inches
is it an overdrive? I was under the impression that is a one to one 5th gear, and a real deap first. (which, IMO is better anyways)
06-03-2007, 10:33 PM | #9 |
these have a .68 overdrive, i looked at a richmond 5 speed but they are the one with deep first and 1:1 fifth
06-03-2007, 10:42 PM | #10 |
nv35/4500's are a truck transmission. If you want more of a car type trans for racing, or just street cruising, go with the TKO.
06-03-2007, 11:01 PM | #11 |
06-03-2007, 11:16 PM | #12 | |
There is a TKO-500, and a TKO-600 (500ft/lbs, and 600ft/lbs) |
06-03-2007, 11:17 PM | #13 |
I have had a TKO series tranny for a while. Fine transmission> try this link...
http://67-72chevytrucks.com/vboard/s...d.php?t=203848 Attached is a shot of the transmission installed using a transmission crossmember from Early Classic Enterprises. |
06-03-2007, 11:48 PM | #14 |
thanx for the classic chevy link, i looking into a 500 because it a little cheap then the 600, never the less i will probaly use a tko600 and spend a little more just in case i decide to go mad with the engine,the nv35/nv45 are big for my tastes i run a muncie now and i like the fact that they are light(i picked mine up by myself yesturday) and you have alot of room around them, i read that you need to have them alighned to you bellhousing, whats all involved in this, i thinking about selling my 58 apache to fund this swap, don't want to but might have to i like the idea of over drive though
06-03-2007, 11:50 PM | #15 |
what shifter location works?
06-04-2007, 12:56 AM | #16 |
Screw the overdrive.....where are the old school boys?????? Muncie....Muncie.....Muncie M-22!!!!!!!!!!!!! LOL just having fun cuz that's what I got............
'68 Chevy SWB with 460 BBC Muncie M-22 and Eaton posi rear w/ 3.73's Corvette rallys with mini derby caps Sick horsepower and torque |
06-04-2007, 01:07 AM | #17 |
yeah, dubs i got an m21 but its starting to get alot of shavings and makes alot of noise ithink these will be just as good but with one extra gear
06-04-2007, 12:28 PM | #18 |
Fabricate till you "puke"
Well, if you can live with of the expense the overdrive, it will put a smile on your face! My longhorn runs a 3.40 gear, with a 6 spd Richmond......just a tick over 3100 in 6th is right @ 105 mph on the open hyway L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
06-04-2007, 12:37 PM | #19 |
I'm a part of the above thread ... I had the chance to drive my truck with the NV4500 that I mention in it. I had my GPS unit with me, yesterday, so I could gauge my rpm's-MPH. Here's what I saw ... 2000 rpm = 60 MPH 2500 rpm = 75 MPH Yes, the "REAL" 1st gear is ultra low. Using the stock master-slave cylinder. Had to mock up a piece to get the master cylinder's "plunger" lined up with my clutch pedal. Works great with an appropriate amount of effort and throw. By no means do I see this as a "street" or "strip" setup, but it is functional and durable. Burned about 1/4 of a tank for 120 mile round trip. Thanks, Dave |
06-04-2007, 12:39 PM | #20 |
... sorry, just "subscribing" to the thread ...
06-04-2007, 11:54 PM | #21 |
The Richmond "6" is a 5+o/d.They are spendy,though.I`d like one of those or an M-series w/Gear Vendors.That would be awesome.
06-05-2007, 12:07 AM | #22 |
thats nice but i am old school
1967 chevy one ton wrecker truck 327 eng 4 speed tranny 411 rear grear soon to be 373 |
06-05-2007, 12:49 AM | #23 |
i priced a GV-OD, it would be nice then i could split all the gears, like the dad's 389 peterbuilt(maybe not) but for the price i could get a brand new all in one trans that would require less fab to install i like the richmond 6 but wow thosae are expensive
06-05-2007, 07:25 AM | #24 |
I agree.Dollar-wise,the Richmond 6spd would be the easiest and cheaper route.I`d like a GV in my`92 K3500 with a NV4500.It`s a marine-prepped 6.5TD with 300hp.Theres no wastegate on the medium duty turbo and the inj.pump is puttin`the coals to it.It makes best power above 2,000rpm,kinda laggy(and smokey)below that.I`m just wasting fuel and losing power.If I could split gears I could keep it in "the range",like the heavy trucks.I love going 1st to 2nd to 3rd,but then it`s drawn out.A six speed would be better.
