06-04-2007, 11:39 PM | #1 |
1966 C-10 Rear End
I HAVE A 12 BOLT REAR END WITH 4:11 GEARS ,WITH A 6 HOLE PATTERN. AND THE QUESTION IS HOW CAN I CHANGE THE BOLT PATTERN WITHOUT CHANGING THE REAR END,CAN I CHANGE THE AXLES OR DRILL NEW HOLES ? CAN YALL HELP ME THANK YOU
06-05-2007, 12:02 AM | #2 |
Re: 1966 C-10 Rear End
4:11 huh? that stock? i dont recall ever seeing 4:11 gears in a 64-66 truck.
Respect: 1. A feeling of appreciative, often deferential regard; esteem. 2. The state of being regarded with honor or esteem. 3. Willingness to show consideration or appreciation. When you fail to show consideration to others values you are showing disrespect. |
06-05-2007, 02:56 AM | #3 |
3.73:1 was the factory 12 bolt rear end installed in the '64-'66 Chevy C10 series trucks. I have purchased a 3.08:1 posi on eBay and I see them on there frequently. They sell the entire master set up kit. I think I paid in the neighborhood of $375-$400, plus shipping. Do a search for 1966 Chevy Truck and check the search Title and Description box. There will be 1,500-1,800 auction items results. Sift through them and you will find one. Good luck with your gear swap.
Tony Last edited by LILRED66; 06-05-2007 at 02:57 AM. |
06-05-2007, 07:26 AM | #4 |
It Is What It Is
allen1364, Early Classic Enterprises sells 5 lug axles that will fit your rearend. They are 5 on 5" pattern like the later model trucks. Check their website. Kevin
