Old 06-04-2007, 09:21 PM   #1
Ram-Man
Ram-Man's Avatar
replacement rocker quality ?
I'll try this on this board because it seems like everyone roams here and not paint and body. These are Triplus rockers do all the brands have these lines on them from the bender? This is the part you would step on. I'm curious what the other brands look like.
Porterbuilt 8 Lugger
http://67-72chevytrucks.com/vboard/s...d.php?t=691739
Ram-Man is offline   Reply With Quote
Old 06-04-2007, 10:15 PM   #2
brak
brak's Avatar
Re: replacement rocker quality ?
mine are perfectly smooth, but i got them from certifit...
light skimming of body filler, or a couple coats of primer, and i doubt you'd even know those lines were there
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 06-04-2007, 11:25 PM   #3
I`ve never seen that on Tri-Plus rockers.Must have been a bad run.From all I know,Tri-Plus is the best rocker you can get.Definately heavier.
Old 06-04-2007, 11:52 PM   #4
byrd
Union Electrician
byrd's Avatar
Mine are the same way, and I have 2 sets just alike. Sucks don't it? Get a new part to avoid more work and end up with more work than you hoped for
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 06-04-2007, 11:59 PM   #5
Frizzle Fry
Frizzle Fry's Avatar
Yep, Mine have the same. From Triplus too. I don't think it's a big issue personally.
Frizzle Fry is offline   Reply With Quote
Old 06-05-2007, 12:00 AM   #6
1969k10stepside
I have Tabco patch panels on my trucks and love them! Never had any problems with them.Made in the USA too!That's the only company I will use for body panel replacement.
Those rockers don't look to bad though,they can be fixed.
1969k10stepside is offline   Reply With Quote
Old 06-05-2007, 12:13 AM   #7
BCOWANWHEELS
i,d return them
BCOWANWHEELS is offline   Reply With Quote
Old 06-05-2007, 02:50 AM   #8
Aarons72s
Mine were like that too but since I will step there anyway didnt care. Mine were triplus to from 2000, when I bought them.
Aarons72s is offline   Reply With Quote
Old 06-05-2007, 03:21 AM   #9
GREASEMONKEY72
GREASEMONKEY72's Avatar
nothin you cant fix or just leave, could always put grip tape over it
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 06-05-2007, 07:04 AM   #10
I was just looking at some compared to thers and all I noticed was how much nicer the Tri-Plus were.I wouldn`t want to have bondo in a wear area like that.I`ll have make sure to only buy ones I`m holding.I`ve only used GM parts before.
Old 06-05-2007, 07:35 AM   #11
Ram-Man
Ram-Man's Avatar
It is an easy fix but if Triplus makes Goodmark I'm suprised Goodmark would approve. This is the main part of the rocker you see.
Old 06-05-2007, 07:48 AM   #12
Huck
Huck's Avatar
Goodmark quality is a joke---they just repackage and add a premium. Aftermarket rockers tend to be about 1/4 inch shorter too so when you install, tack first then close the doors to make sure you have the proper clearance---it is most noticeable when you seam the front and rear against the A and B pillars.
Huck is offline   Reply With Quote
Old 06-05-2007, 08:49 AM   #13
Goodmark was selling doors with the window frame 3/8" too high.They finally changed them.
