Old 06-04-2007, 08:26 PM   #1
1969k10stepside
Question Do they make such a thing???
As pre bent brake lines kits just for the front.I looked and cant find any for my 71 4wd.I ran the back axle lines and the line that go up the frame rail towards the front of the truck but the engine bay looks to have alot of bending to do and Im bending the lines my self currently.If I could find a kit just for the front that would be great.The sooner the front lines are ran,the sooner the motor goes in!
1969k10stepside is offline   Reply With Quote
Old 06-04-2007, 10:24 PM   #2
eedgell
It's the air up here
eedgell's Avatar
Re: Do they make such a thing???
If you wanted to go used you could look for a pull off. If not, then you are better off bending them your self. I am not aware of any brake line kit. Have you tried your local GM dealer?
1971 cheyenne k10 4 speed np 205 454 BB factory a/c
Never drink down stream of the herd!
Eric
eedgell is offline   Reply With Quote
Old 06-04-2007, 10:47 PM   #3
67CHIP72
STOLEN
67CHIP72's Avatar
I was thumbing through classicparts.com catalog, and it looks like they have a 10 piece set for 71 4x4 shortbed, but they don't specify which lines. You might call them tomorrow.
In Search Of
67CHIP72 is offline   Reply With Quote
Old 06-04-2007, 10:50 PM   #4
centsless
sufficiently talented fool
centsless's Avatar
Check inline tube (they are online),or one of the board vendors. If they can't help, I think LMC sells them as a full kit, or you can get individual pieces.
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
Old 06-04-2007, 10:55 PM   #5
Misled
Misled's Avatar
You can try www.getdiscbrakes.com , which is Right Stuff Detailing in Sunbury, Ohio...
Misled
Misled is offline   Reply With Quote
Old 06-04-2007, 10:58 PM   #6
truckdude239
truckdude239's Avatar
www.inlinetube.com is where i got my whole set for 157 buxs
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 06-04-2007, 11:18 PM   #7
LMC (at least) will sell whole kits or partial,like you want.Inline will sell any way you want.
Old 06-04-2007, 11:34 PM   #8
1969k10stepside
I looked at lmc and didnt see anything but 2wds listed...A 2wd kit wont work on a 4wd.Do the lines that run from the master cylinder/proportioning valve that run down to the frame differ on 2wd and 4wds?Pic below.I was thinking if I get that,I can bend the rest of it myself.I really dont wanna fork out the money to buy a whole kit since I just spent money on lines and a bender to bend them my self and have already bent all the lines from the rear axle to the engine bay.I was hoping they had a kit,like the one to the left of whats circled in red but its lists C10s,not K10s
Old 06-05-2007, 12:08 AM   #9
trkklr77
trkklr77's Avatar
Location: vacaville ca, because it as far from indy as i can be
seeing as how they come out in the same places what does it matter?
trkklr77 is offline   Reply With Quote
Old 06-05-2007, 02:53 AM   #10
Aarons72s
Lmcs brake lines are hit and miss, a friend ordered a set and they were way off but we made them work. I went with inline tube for mine and they are great. Id go with them again. Dont use classic tube, they are a pita!
I cant rember but does gmcpauls sell the lines? Might want to check since they arent to far from you, dustin.
Aarons72s is offline   Reply With Quote
Old 06-05-2007, 03:05 AM   #11
GREASEMONKEY72
GREASEMONKEY72's Avatar
dont be a wimp and just bend them
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 06-05-2007, 07:11 AM   #12
I should have looked at the catalog first.Hmmm...only 2wd.The only place the 2wd vs 4wd frame rails differ is right in that area.The 4wds rise more.Probably why they`re listed different.LMC is usually right for a reference on application of hard parts.
Old 06-05-2007, 09:06 AM   #13
truckdude239
give inline tube *a call they can fix you right up
David fuller
2000 Tahoe 5.3l 378
Old 06-05-2007, 10:53 AM   #14
1969k10stepside
I checked and they only had full kits.
Might have too,but the motor is going in tonight brake lines in or not!
They are next on the list to call today
Old 06-05-2007, 11:33 AM   #15
jamesi20
jamesi20's Avatar
http://www.rightstuffdetailing.com/ try these guys as I have had good results with them in the past.
jamesi20 is offline   Reply With Quote
