Re: does this look right?
I did not read all the posts, but I disagree with most. Correct me if I'm wrong, but you are not using that front crossmember, you just didn't want to cut it out. An auto crossmember WILL AND DOES work perfect for a 4 speed trans mount. You can play with your output shaft height with different trans mounts that bolt to the x-member. You also want some angle to your driveline which is why you have joints. I just went from 250 inline 6 and granny 4 speed to a 460 BBC and a Muncie M-22. I cut out the forward trans mount. CANT USE 6 CYL mounts, Must use BBC. CAN USE AUTO crossmember. My motor has quite a bit of tilt, and the driveline angles up. result......A tire-frying scary ride with ZERO vibration and everthing works perfectl
'68 Chevy SWB with 460 BBC Muncie M-22 and Eaton posi rear w/ 3.73's Corvette rallys with mini derby caps Sick horsepower and torque |
![]() Join Date: Apr 2007
Hmm....Im wondering if there is a piece of square tubing that Might be sufficiant. any ideas?
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=456220 Best 1/4 mile time 12.1 @ 111 w/traction issues 1969 GMC SWB 1964 chevy II Nova ht |
i agree you should have no problems if switched out automatics to standards and vise a versa and NEVER SHIMMED A THING in my travels if seen this a thousand times and never seen a shimmed trans in my time here's mine yes it tilts just like yours 350 sb turbo 400 trans will get a better pic for ya
1972 c-20 chevy 500 caddy/4.10posi / 1972 3/4 ton gmc 350 4x4/4.10posi front&rear ![]() ![]() ![]() |
Junior Member
Mine has the same tilt and has since I bought it. I do have a 1/2 spacer on my tranny mount though. I'm running 6cyl mounts with a 350.
#5 | |
Yes Please send me a pic!
Wow lots of different views and opinions on this one. So far Im told that my motor brackets are 6 cyl and they are V8. Im also told that the motor should be tilted like mine and it shouldn't be? Im told that I want the driveline to angle up slightly and Im told I dont? Also keep in mind that this truck will be going very low in the next too weeks. I need lots of advise on this one guys? I need to get the exhaust pipes rebent around the new crossmember ASAP but I dont want to do it untill its right.
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=456220 Best 1/4 mile time 12.1 @ 111 w/traction issues 1969 GMC SWB 1964 chevy II Nova ht Last edited by tranz am; 06-06-2007 at 12:33 PM. |
#7 | |
#8 | |
That angle is a little steep.....just need enough angle to make the carb mounting pad level.
And yes....I know that the level is levling the wrong angle where talking about here, these are the only pics I have relating to what were talking about though.
I think I will shim the Transmission. and figure out the drive line latter. Thanks for clearing that up.
