05-26-2007, 01:49 AM | #1 |
Straight "6" Shooter
Went back original....
I was having problems with my HEI distributor, so I decided to put the original points and condensor distributor back in. Got a good deal on a new unit, 42 for the distributor, 3 bucks for the rotor, and 5 bucks for the cap. Got some new wires as well. Put it together, and realized that I didnt have a coil. So I robbed the mopar coil off of my parts mercedes benz (dont ask... please) hooked that up, and wired directly to the battery. I think I am 180 out on the distributor tho, it acts exactly like it did when I first got it. So, I am going to turn it around tomorrow morning sometime and see what happens.
I also have the spare HEI distributor, which I no longer need. All I got out of her tonight was a big BOOM! So I know that I have spark. Anyways, I'll update as I make progress.
1966 LWB 292 I6 & Granny Low If you listen intently, you can hear a FORD rusting in the distance. My LUG NUTS take more TORQUE than your HONDA makes! |
05-26-2007, 08:59 AM | #2 |
Hollister, CA.
Re: Went back original....
I'm surprized you went back to the points style distributor. The HEI has a hotter spark, and a hell of lot easier to hook up. Good Luck.
John
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
05-27-2007, 07:49 AM | #3 |
ive got the og points and it runs better than a couple of my friends that have HEI
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
06-04-2007, 06:37 PM | #4 |
I have a pertronix kit, keeps it looking stock with electroins inside the cap works great !
06-04-2007, 07:04 PM | #5 |
Good luck with getting her spinning again. I am going to check into the Petronix set-up. I prefer the stock look. Thanks for heads-up.
Tony |
06-05-2007, 04:59 PM | #6 |
I really like my HEI. I used one off a late 70's with the coil still seperate from the cap. I used a MSD high vibration coil and going to add MSD 6 offroad when I figure where to mount it. The only problems I've with the HEI conversions is people use the stock + coil wire wich has built in resistor.
06-05-2007, 06:49 PM | #7 |
baddawg65:
I like the looks of your 292. Well done. I see you have an electric fuel pump. Tony |
