Don't say "Oops!", Doctor
Temp gauge problem - sending unit or gauge?
The needle on the temperature gauge in my 68 moves from zero to about 1/5 of the way up when fully warmed up. Needless to say, this isn't normal. I'm just wondering which I should tackle first, the sending unit or the gauge itself. Anybody ever have this problem?
'Mutt 1968 CST LWB: R.I.P. 1967 Chevelle: TPI 454 beast 1967 C10 SWB: Claimed when Bumpster didn't put it on his list |
Live life and be happy.
I would check the thermostat also.
has it always doen this? or is this abnormal... the first part of the gauge is about 80% of the degree scale and the other 80% of the gauge is the high temperatrues you dont want to be reading at
70 longbed 496/th400/Ford 9" |
Hmmm... if there was no thermostat (or it was stuck open) then the engine would eventually reach operating temperature, but it would take longer. On the other hand, if the thermostat was stuck closed then the engine would get hotter and faster. Am I missing something? It wouldn't be the first time!
#5 | |
First mark past cold is approx. 180* Have a direct reading gauge also and it reads 180* when stock gauge is to 1st mark. When direct gauge goes up to around 200* (in traffic) stock gauges only goes a little past the 1st mark. This is normal range for stock gauge.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
![]() This is what my gauge looks like when the truck is at full operating temperature. I've seen it creep just a little beyond this point, but not much. If I understand jhow66, this is approximately 180 degrees, right? If that's right, it sounds like my gauge is just fine and I just didn't know how to read it. Huh... I coulda swore they went nearly straight up at full operating temperature. Oh well! One less part I've got to replace. Woohoo!
user # 2756
![]() Join Date: Jun 2001
Mine goes straight up and down w/ a 190 degree thermostat. Sounds like you might have a sender for an idiot light and not a sender for the gauge they are different.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
D'oh! I thought that was a little screwy. Hell, it's not like replacing the sending unit is expensive or time consuming. I'm gonna bite the bullet and make sure I've got the correct, working unit. Thanks JIMs70GMC!
#10 | |
CCRider
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
I have experienced both sides of this issue. My gauge used to read at second mark at normal temp. Then the sending unit crapped out. I have replaced it with 3 different senders and they all read at different part of the gauge at normal temp. The current one I ordered from Lectric Limited, who claimed it was calibrated correctly. The normal range is now straight up, but the gauge goes up almost all the way to hot before the thermostat opens. It is not a comforting sight! What gives? Does anyone sell a matched sender/gauge?
'72 Chevy Suburban Custom Deluxe 10, 402/TH400 |
user # 2756
grebus1 mine does the same thing what I think it is, is more fo a coolant flow problem near the sending unit. and the thermostat is open but it (cooler water) take's time to purge out all the hot water. or the the hot water takes awhile to get to the thermostat. Mine does it in the summer and winter, and even after replacing the thermostat.
Well, now I'm as confused as ever. Should the needle be straight up when at "normal" operating temperature? Is that the goal?
user # 2756
Yep! At least mine is just every now and then it goes past then comes back to the middle, usually when I first start it each day.
#15 |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
shuttermutt, I have had several trucks over the years and all of the gauges have read what your gauge is reading now. Yours may be slightly cooler. I run 180 degree thourmustats and the needles rise just a little above the first tick. It looks to me like yours is reading normaly. WES www.ClassicHeartbeat.com
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
#16 |
Thanks WES (and thanks to everyone else, too)! I think that I'm going to leave well enough alone for the time being. I may go ahead and stick a thermometer in there when I get a chance and verify that she's not running too hot.
#17 |
Firefighter
Your reading is correct shuttermutt, that's usually where mine runs with a 180* degree thermostat, in all of my trucks.
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA ![]() ![]() |
#18 |
Re: Temp gauge problem - sending unit or gauge?
I just got my '70 running w/ an LS1. I used a VDO sending unit on the rear of the passenger side head, via a reccomendation from another online source, and a 160* thermostat. After about 5-10 minutes it runs the guage up to the top of the normal range, and would keep going if I didnt shut it off. The top, bottom & heater hoses are hot but theres no circulation in the radiator and its cold to the touch. What is the temp range for the stock guage? Am I not letting it get warm enought to open the therm. Is it possible that the sending unit is for an idiot light and not a gauge,or that it's not running long enough to open the therm even though it's creeping uncomfortably close to the "H"? To me it seems like the water pump is not pumping- but is that possible w/ the motor running? Theres no leaks and theres only 30,000 on the motor so I'm assuming the pump is still good... Any ideas?
#19 |
1972 Shorty Owner
Location: Stationed in Cali , born and raised in PHX Arizona.
Check this thread here. I posted a few picks of my temp gauge in here. If yours looks like this your good to go.
http://67-72chevytrucks.com/vboard/s...d.php?t=235946
1972 Chevy Shorty C-10- Project In Work http://67-72chevytrucks.com/gallery/...ATT1721941.jpg- New Project Last edited by JHART; 06-07-2007 at 05:19 PM. |
