rear end
My rear diff was leaking so I decided to change the cover and replace the fluid. Wasnt sure if it had a posi in it. Is this a posi unit? And how much fluid does it take?
Re: rear end
Yes,thats a posi rear axle.I fill mine up till the fill plug where it's about to pour out.
Re: rear end
cool thanks.... does the posi need any special type of gear oil or additive?
Re: rear end
Yes, you need a limited slip additive, or a gear oil that already contains the additive.
Tim |
The LuvShack Garage
Re: rear end
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
Re: rear end
Lockers are better anyway. If you're not locked, you're stock! The Eaton Posi is a nice thing to have otherwise.
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
Re: rear end
Just for information. That is an Eaton you have their guy. I have one just like it in my 72. Have had to rebuild it several times. Had a heavy foot when I was younger. Good units, but not real strong. Like the guy said, Just fill it till it comes out the hole while the truck if level. If it starts klunking when you back up, add some additive to it. they use to sell whale oil for the clutches. Now it's synthetic.
