Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 06-13-2007, 10:18 PM   #11
Frizzle Fry
Frizzle Fry's Avatar
Re: Joined the Short Wheelbase Club *69 Tahoe Project*
Originally Posted by LUV2XCLR8 View Post
Sweeeeeeeeeeeeeet. I have the same one, uninstalled, was it easy to do?
Well, I couldn't get the OG stud out of the rear end. Must need a press or something and I'm not taking the whole thing out at this point. So I ended up hacking it off...
The other thing I found is that you need to put the bar in place at both ends BEFORE you tighten up the passenger side U-Bolt. This is because there is some play in the bracket's U-Bolt holes. So if you install the bar you can clock the bracket correctly, then tighten the U-Bolt.
Also, I already have lowering blocks and longer U-Bolts so the nice new one's that come with the kit are useless to me. You may be able to ask for longer ones if you already have blocks.
Originally Posted by Hart_Rod View Post
What drop did you go with? Quit holding out, .
Alright, alright Bags (SS RE7's) for all four corners, the top digital air management package from SD, KP step notch, and some of their weld-on shock brackets. I'm going to put the rear bags in the stock location for now and see how I like it. The 2.5" lowering blocks plus bags should get me pretty low
I also have my quarter glass and all the rear seals on the way
Frizzle Fry is offline   Reply With Quote
