Old 12-10-2002, 11:25 AM   #1
694X4
694X4's Avatar
change hump???
I have a 72 3/4 ton 4x4 that i am puting a 69 2wd cab on with the small hump. Do I need the large hump for the 4 speed or will the the small hump work? If I need the large hump I have the bolt in hump can I cut out the floor and bolt in the large hump? Thank for any help.
69 3/4 ton 4x4 gmc with 6" sky jacker soft ride. 350 / th350 / 205
work in progress
694X4 is offline   Reply With Quote
Old 12-10-2002, 12:16 PM   #2
junkyardjohn
junkyardjohn's Avatar
NO ONE SEEMS TO BE ANSWERING YOU SO HERE GOES...... YES YOU NEED A HIGH HUMP FOR YOUR 4 SPEED 4WD. CHANGING IT IS A PIECE OF CAKE. JUST CUT OUT YOUR LOW HUMP & BOLT THE HIGH HUMP IN.
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 12-10-2002, 12:19 PM   #3
694X4
694X4's Avatar
Thanks that is what i needed to know.
work in progress
Old 12-10-2002, 12:21 PM   #4
crazy longhorn
Fabricate till you "puke"
Yes, you will need the large hump for 4 spd, or 4wd. You should be able to cut your small hump out & add the large hump with minumul work.......just use the large hump for pattern/spacing. Good luck...crazy AL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-10-2002, 12:27 PM   #5
694X4
694X4's Avatar
Thanks for all your help guys looks like I need to pick up some cutting disks on the way home.
work in progress
Old 12-10-2002, 02:49 PM   #6
Low69CST
You need to get some body seam sealer too. If you don't you'll be getting water around where you bolt in your big hump
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 12-10-2002, 02:54 PM   #7
694X4
694X4's Avatar
good idea i never thought of that. I just ordered a carpet kit about an hour ago glad you said some thing before i put it in. thanks
work in progress
