68 gmc auto shifter trouble...
Hey guys,
My boys truck has started shifting out of park and back in real hard. its like when you pull back to shift its not releasing or something.. sometimes its hard to shift from neutral to drive.. you guys ever dealt with this. is this an easy fix. your help is greatly appreciated.. thanks Andrew |
Zappaphile!
Re: 68 gmc auto shifter trouble...
have someone move it around for you while you look at the mechanisim and see if you can see it binding anywhere..
Does it do it all the time, or just when its running??
1969 C20 LWB Camper Special - The Beater.. 1998 Cheyenne V6 - 4/6 Drop - For The Son |
all the time and is only getting worse...
![]() ya i already had the boy shift it and i looked at the shift linkage on the fire wall side. theres like a ball that runs in a divet plate for each gear. theres a major lump on the plate that the ball goes over into park. i greesed it and it did not help. once you get it to shift into park or drive and you hold the sifter towards you it shifts easy cause the ball or ball area on the linkage is retracted from the plate. it has to do with somthing that makes that ball lift away from the divited plate. i just don't no what. i was hoping there was an adjustment some were.. dont really want to rip outh the colomn.. Last edited by 57sailplane; 06-16-2007 at 05:19 PM. |
When you move the shifter you have to pull(or "lift") the lever towards you to clear the stops. It prevents accidentally shifting from drive to reverse, reverse to park, drive to L2, etc. Are you doing that or just trying to push the shifter without lifting it?
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck Last edited by Robert1970C20rstbukt; 06-16-2007 at 05:58 PM. |
#5 | |
Need a bigger hammer..
1968 GMC 3/4 LWB fleetside Custom Camper 2018 Silverado High Country 2500HD Duramax 4X4 |
yes,
i am pulling back ont the shifter and i greesed the area with the detent... were else can i lubercate without total disasebly.. |
