Old 06-17-2007, 06:21 PM   #1
Husker
Husker's Avatar
Power steering problem
Just got My steering swapped over to Power. It works great turning to Right and almost not at all going to the left. I used a used box that is the right box and Pump that was also used and right for the application. I have a 70 GMC 4x4 350. New lines.
It turns easy to the right, I can let go of the wheel and it will keep turning by it self. Going to the left it is harder like the pump is not working or something is plugged.
No leaks to speak of and the belt is tight.
Any help would be appreciated.
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
http://67-72chevytrucks.com/vboard/payments.php
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 06-18-2007, 04:18 AM   #2
JimKshortstep4x4
Re: Power steering problem
It sounds like your problem is the steering box itself as the centering valve must be bad.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
