Old 06-14-2007, 03:48 PM   #1
63chevyfleet
63chevyfleet's Avatar
brake switch problems help!
on my 63 my brake switch by the pedal. im trying to see wut wires got to that because the previous owner ran a wire from the switch all the way to the back were the tail light wires are then it is tapped in the tail light wire's. the wire that he ran was for the brake lights to go on when at a stop. so can anyone one help with a diagram of just that if not then type in words if possible thanks!!!!!
63chevyfleet is offline   Reply With Quote
Old 06-17-2007, 01:34 PM   #2
Fred T
Cantankerous Geezer
Fred T's Avatar
Re: brake switch problems help!
Here's the diagrams for a 64. http://67-72chevytrucks.com/vboard/s...wiring+diagram
Brake wiring should be the same as your 63.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 06-18-2007, 07:00 AM   #3
60ratrod
yes, i do
60ratrod's Avatar
hey i have a wiring diagram for a 60. i could take a look if you need.
60ratrod is offline   Reply With Quote
Old 06-18-2007, 07:55 AM   #4
hewlett2002000
hewlett2002000's Avatar
i just got done wiring my truck so i know how its wired. a hot wire from the fuse box(always hot) goes to the brake switch. then the other terminal on the brake switch hooks to the tun signal wiring on the column. it doesent run to the back. hope this helps.
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
Old 10-23-2008, 06:00 PM   #5
gotmud
gotmud's Avatar
Let me borrow this post....
Im trying to wire my 64 and am not able to find the brake light switch....ugh.
Anyone have a pic of what it should look like or where it is located?
Im looking all around the cab and see nothing around the pedal that would hint at being a switch.
Sorry for the noob question.
Glenn
Cumming, Ga
(68 C/10 Fleetside LWB 307
(64 C/10 Fleetside Shorty Custom 350, with 73 donor parts aplenty)
(2001 Porsche Boxster S - 168 MPH of fun)
(2005 Chevy Avalanche Z71 1500)
gotmud is offline   Reply With Quote
