Old 06-17-2007, 10:26 PM   #1
BCOWANWHEELS
th 350 neutral safety switch part number needed
i need the GM part number for the neutral switch on the side of a th 350 in a 1972 pickup. i hope there still available from GM. my backup lights wont work and the fuse & bulbs are good. any help appreciated.
bob in tn.
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 06-17-2007, 11:01 PM   #2
jhow66
jhow66's Avatar
Re: th 350 neutral safety switch part number needed
Switch for both are on steering column under dash not on trans.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 06-18-2007, 01:42 PM   #3
BCOWANWHEELS
thanx, got part numbers ?
bob
Old 06-18-2007, 03:15 PM   #4
jhow66
jhow66's Avatar
Are they hooked up? If they are , remove the backup plug off switch(green wires) and jump across the plug with a jumper wire. Turn on switch and lights should come on. If the do try adjusting the switch. (will your truck start in park and netural only?)
Old 06-18-2007, 03:25 PM   #5
Orange
Licensed to Thrill!
Orange's Avatar
I would troubleshoot first...
But if you can't get it working - http://www.brotherstrucks.com/prodin...number=NSS72TH
DLB
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
Old 06-18-2007, 11:06 PM   #6
BCOWANWHEELS
Truck Starts In Nettral And Park Only. I Jumped The Green Wires, Turnned Switch On And Bingo They Worked. So Switch Is Worn Or Bad Right ? Thanks A Bunch For You Help......
Bob
Old 06-19-2007, 07:57 AM   #7
Orange
Licensed to Thrill!
Orange's Avatar
It may just be out of adjustment if you are using the stock 3-speed tranny and column.
Have you tried adjusting the switch around the column? There is a fine line where all three things mesh.
The adjusting procedure goes like this:
Have an assistant stand in back of the truck.
Chock the wheels, or use the parking brake if it is good.
Place shifter in reverse and turn the switch to on.
Slide the switch back and forth untill the back up lights are on.
Test it in park and neutral... it should be good.
DLB
Old 06-19-2007, 02:35 PM   #8
BCOWANWHEELS
called advance auto and they had switch for 12.99 ( sorenson brand ) then i called orileys and they had it also only in borg warner so i bought it thinking borg is better. they price matched advance auto. 12.99 so i,am just gonna swap it out to be done with it. its obsoliete from chevy come to find out. but chevy does have the repop ones for 80.00. thanks all you guys for your help.
bob
