Old 06-20-2007, 03:40 PM   #1
LowStep79
Fuel Cell In...
Well I finally finished up the fuel cell today. Its all wired and plumbed... enjoy! Anyone know what I might be able to get for the stock tank with everything in it? Sending unit, and brackets?
LowStep79 is offline   Reply With Quote
Old 06-20-2007, 03:43 PM   #2
bigblock73
yeller
bigblock73's Avatar
Re: Fuel Cell In...
You have it in backwards, the pickup should be to the rear of the truck. Also, your vent should make a loop (I can't tell if it does or not), helps to keep dirt and debris from entering the fuel cell.
Looks good otherwise.
bigblock73 is offline   Reply With Quote
Old 06-20-2007, 03:43 PM   #3
82c10
needin' money
Re: Fuel Cell In...
that much rubber fuel line is a no-no
82c10 is offline   Reply With Quote
Old 06-20-2007, 03:45 PM   #4
bigblock73
yeller
bigblock73's Avatar
Re: Fuel Cell In...
I missed that, you are correct.
Old 06-20-2007, 03:46 PM   #5
LowStep79
Re: Fuel Cell In...
Care to elaborate? And why the pickup to the back? I'm learning...
Old 06-20-2007, 03:48 PM   #6
bigblock73
yeller
bigblock73's Avatar
Re: Fuel Cell In...
I was replying to 82c10
You shouldn't use that much rubber line for fuel, you should hard line it or use stainless braided line. Safety issue.
Pickup is always in the rear because upon acceleration, fuel is pushed backwards...and if the pickup is in the front, fuel may not make it out of the tank up to the engine. I asked many people when I did mine, including a local reputable speed shop...they all said put the pickup in the back.
I wondered if the same was true for braking...but was never given a good answer.
Old 06-20-2007, 03:53 PM   #7
swb85
On a budget like Fred Sanford
swb85's Avatar
Re: Fuel Cell In...
You want your pickup to the back because under acceleration the fuel will move to the back of the tank.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 06-20-2007, 03:56 PM   #8
LowStep79
Re: Fuel Cell In...
Hmm guess I shoulda asked a few more questions before I got it in and a half a tank of fuel...
