Tilt Wheel Conversion
Hi gang. need more help. I came up with a factory tilt column out of a 72 . Will this convert without hassle in my 68 or are adjustments needed in wiring and steering box hook-up?
Gary |
its all about the +6 inches
Re: Tilt Wheel Conversion
pop your hood, and look at thesteering shaft.
If it is one piece from the column, to the steering gear box, then you'll need to get an intermidiate shaft off a late 68 - 72. If it already has the Intermidiate shaft... as in the column bolts to a shaft that bolts to the gear box, then it should be a simple remove and install. |
