Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 06-21-2007, 02:23 AM   #11
DURRTY
USMC
DURRTY's Avatar
Re: Got Rust?
Originally Posted by 72CSTC5 View Post
You guys are my heros, I would not touch that thing with a 10 foot pole. The best of luck to you there buddy. Why don't you spend more money on one in good shape then spending 1,000.00 dollars in replacement panels, time, money, mig wire, grinding disc, primer, sealer, undercoating, etc. You would save a lot more money buying one in better shape and starting from there.
One big reason for me is that I am a fabricator/welder and used to be a pipe welder. I have more consumables (aside from any primer paint......) than I have room for. the grand or more in sheet metal plus other parts to get it running will still get me under what an even close to rust free blazer would cost around here. South of me in AZ they know what there rust free rides are worth. Then add a ton more if the thing has a good engine and drive train. id be looking at close to 10 grand.
Mine has a bone stock but rebuilt 350 and a good drive train, all the outer sheetmetal has been replaced or patched. good top so I took it over the built up rusty ones or the high priced rust repaired ones. Plus when its done(this is the most important to me) is when I get asked did you do the work? buy it like that or pay to have someone do it? I can say HELL YES I BUILT IT and its EXACTLY how I want it.
Its going to be sixes on the money saving too. If planned out properly both ways can be cheap or expensive.
Jeff
Semper Fi
DURRTY is offline   Reply With Quote
