anybody know if 35 inch tires will fit under a 6 inch lift
yea i really could use yalls help cause i am wanting to lift my 83 swb GMC sierra 1500 and do yall know what kind of motifications i might have to make on it if yall could reply back to me with yalls answers i would greatly appretiate it
EZEKIEL 25:17
Re: anybody know if 35 inch tires will fit under a 6 inch lift
68 CHEVELLE(HORSESHOE) 69 LONGHORN 396 70 NOVA 454(FOR SALE) 71 SWB 307 71 EL CAMINO 383 72 GMC JIMMY 350 87 BLAZER 350 WIW? http://blog.360.yahoo.com/blog-r5CJt...9_6Orzim4L5uWM Gun control, the theory that 110lb. women have the "right" to fistfight with 210lb. rapists. The reason animal rights activists are more passionate about fur than leather is because it's safer to harrass rich women than bikers... Last edited by LonghornJeff; 06-21-2007 at 10:17 PM. Reason: more stuff |
It's the air up here
I think 4in of lift will get it done as long as you are not wheeling real hard. In that case 6in is better. Mostley the front corners of the front fenders will take a beating when wheeling hard with 35's and 4in. The rear will be just fine. Unless you like the big rocks, or you have a lead foot and like to jump, you will be fine with the 4in. and 35's.
1971 cheyenne k10 4 speed np 205 454 BB factory a/c ![]() Never drink down stream of the herd! Eric |
Chevys Kick A$$
6" lift should be fine. U probably will have to lengthen your drive shaft. 6" lift is on the borderline. Probably will have to extend your brake lines as well.
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
I would go 6". I had a 3/4 ton with 6" and running 35s, and once in awhile I would hit the fender. It was a nice truck, so didn't want any rubbing at all. I was running wide boggers, which didn't help any.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon 350/4L60 6" SAS |
4"Superlift,12.50/35 BFG A/Ts,9.75" steel wheels,Heckothorn Hydraulic shocks.Rode good,never rubbed.Never wheeled it hard either.But,almost always hauling weight.Diesel motor and loaded lader rack put`s the weight up front a good bit,too:
