Trailing Arms Question
Can you help? I currently have a 1969 Chevy Step Side and currently is on leaf spring and 6 lug drums all around. Think it was classified as a heavy duty?? Anyway, I'm interested in converting the leafs to trailing arms. Is this a real nightmare? Is there alot of welding if any? Someone questioned the cross-member. He said I would need the one that resembles an oxen collar. I do have that, It has the drive shaft going thru it. Is this the right one. By doing the swap out, my son want to replace the coil springs for air bags. He says it is a direct swap. If you can answer any of these questions please reply.
Harry 954-704-2213 |
Not a bad nut after all..
Re: Trailing Arms Question
A leaf spring rear suspension 4x2 is relatively straightforward to convert to coils: http://www.earlyclassic.com/Tech.asp...=Spring%20Time
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer |
